Old 06-Jan-2004, 22:03   #11
pj748r pj748r is offline
Mood: FIVE!!!!Guess We'll Keep It
It'l be fine as long as you don't cane it going there.Run mine on standard chip for 2 weeks before i got fitted a chip.Take it you got the link pipes sorted,bloody italian quality control eh!!
Old 06-Jan-2004, 22:09   #12
Nigel C Nigel C is offline
Nigel C's Avatar
Mood: happy bike passed MOT
Cheers pete yes got them on eventually never doubted they would fit
http://ducatisportingclub.com/contro...d.php?tid=5660
[Edited on 6-1-2004 by Nigel C]
Old 17-Jan-2004, 16:33   #13
mike916 mike916 is offline
Mood: Neutral - but only maybe. 1994 Duc 916S1, 2006 Duc Sportclassic 1000 Sport
What if you have a chip that will not budge from the board - P8 management system on my 94 Strada - and I dont want to force it to much? Anyone got a solution? ie is there a form of penetrating oil or anything like that you can use?
Old 17-Jan-2004, 17:02   #14
muttsnuts muttsnuts is offline
muttsnuts's Avatar
Mood: Feeling Sad being Ducati-less :(
try pulling it harder - who err missus !
The last one I had to pull, I needed to get it going using a small falt bladed screwdriver, not the nicest way, but once I cracked the seating, it came out real easy
Old 19-Jan-2004, 13:14   #15
Thanks for that - but eventualy took it to a friend of a friend who has the proper puller - job sorted
Old 19-Jan-2004, 13:45   #16
Mood: aving a laff
The white plastic cover is held on by something akin to molten rubber.
Probably some epoxy etc.
You should be able to grip it with point nosed pliers and remove it exposing the chip underneath.
Once its exposed you will see which way the chip goes in for replacement.
Dont run it for too long with the wrong chip.
I experienced this when I fitted the 50mm Termis and left the 45mm DP chip in.
Went on a DSC run round North Yorkshire and looked like I was on a Petronas in disguise.
Apparently the flames coming out of the exhaust were only over shadowed by the pops and bangs.
Got Nelly to fit my new JHP chip as part of the service and it ran and still runs a dream.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:29.
