Old 18-Jan-2004, 19:14   #11
Dibble
Tim,
Did you get an anorak for xmas ....????
Old 18-Jan-2004, 21:04   #12
Bog off skinny!!!
Old 19-Jan-2004, 00:53   #13
I'll try to add to this soon. i'm going to take a selection of discs into work and weigh them, I know the Spondon ones are my lightest but not there actual weight, will also weigh EBC pro-lites and a few others.
This anorak fits well and its keeping me warm and dry in this weather.
Old 19-Jan-2004, 12:55   #14
Skids........
.........that'll be good.
Just a comment that I did measure these very scientifically - I used some cheap kitchen scales!!
I wasn't too concerned about the accuracy, more on the difference between the disks.
Tim
Old 19-Jan-2004, 13:19   #15
Felix Felix is offline
As already pointed out, it's not the static weight alone that makes the difference. For instance, I have narrow track race Brembo discs in both 290 and 320 mm sizes. As it's the disc itself, not the carrier that accounts for the majority of the weight, a narrow track disc reduces the weight where it counts most. The discs themselves weigh about the same as what you've measured, but they can now carry a thicker disc which last longer and dissipates heat better. Remember, brake systems are a science and very difficult to understand, well, certainly for me.
Old 19-Jan-2004, 13:27   #16
Felix......
.......I'm not quite sure I followed your point. Whay are narrow track lighter?
The waveys are thicker than the R brembos, but weigh virtually the same.
Perhaps the centres weigh less.
They also have the wavey edge that in theory provides a greater edge surface to aid cooling!
How do you accomodate the smaller disks (290mm) with your calipers?
Tim
Old 19-Jan-2004, 16:21   #17
They weigh virtually the same as the standard ones but are thicker at the same time. Were they the same thickness they would be lighter due to the narrower track using less steel.
Proper Ohlins race fork have two sets of mounting holes for the calipers.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:49.
