Old 21-Feb-2004, 11:31   #11
Bryan996 Bryan996 is offline
Bikes: 1098S, 996SPS, CBR1000RR (for when it rains!)
thanks for all your help, as soon as i get a break from selling Honda's i will pull the clutch pack apart and check all the points above. If i find anything I will let u all know.
Old 23-Feb-2004, 10:37   #12
Just an added tuppence worth - I had the symptoms you describe and tried various clutch plate height/orders to not much avail. Eventually got so p*ssed off that I re-fitted a stock clutch; discovered that the slipper's hub was the two part with bearings, which had largely disintegrated. Unless FBF do replacement components, that's a £800 clutch down the swannee.
Hope your problems are of the adjustment variety.
Old 28-Feb-2004, 11:47   #13
I finallly got the thing apart last night and I think the problem is with the plate arrangement( i.e having four sprung plates). Can anyone tell me the definitive plate order for the slipper clutch with dots in or out etc.
thanks
Old 28-Feb-2004, 13:47   #14
There are a few "ideas" on plate arrangement, but here's mine.
I only usually use one dished plate to.
2 Plain plates first, then a friction plate, then the dished one with the dot facing outwards, towards you.
Then fill the basket, alternating with a friction, then a plain etc.
Finish off with a plain plate then fit the pressure plate.
The clutch pack should sit about 4mm below the edge of the basket.
If it doesn't, you can adjust the pack thickness using 2mm or 1.5mm plain plates.
If you still get a bit of judder, replace the outermost plain plate with a dished one, dot facing inwards.
2 dished plates is the most I've used before, so having 4 in there may be the root of your problem.
I have a clutch pack thickness dimension of 35.5mm from somewhere, but this could be applicable to a particular manufacturer. Might serve as a reference measurement though.
Old 28-Feb-2004, 14:32   #15
I assume that you haven't read these threads:
http://ducatisportingclub.com/contro...d.php?tid=3146
http://ducatisportingclub.com/contro...d.php?tid=3513
And the ultimate solution:
http://ducatisportingclub.com/contro...d.php?tid=4134
Old 28-Feb-2004, 15:03   #16
i''ve read those threads and the only one with pack order is for the 998rs clutch. In the order it has no 2mm plates and nine friction plates, I might be wrong but I think i have 8 friction plates and the majority of the steel plates being 2mm not the 1.5mm in the rs clutch.
I'm beginning to think that there is no definitive answer and once the weather is better i will just have to work it out over trial and error. I do think that maybe using just one sprung plate is the answer then making the rest of the pack up the 4-5 mm basket gap.
Old 28-Feb-2004, 18:10   #17
Clutch Tuning Voodoo
Clutch engagement problems are quite common, but solving them often requires a fair amount of trial-and error work.
Usually, an uneven take-up or excessive slipping signals signals the need for a clutch pack replacement, often just caused by normal wear loss of the friction material on the plates. The mileage between replacements has a very wide range, anywhere between 3,000 and 30,000 miles, depending upon the amount of city riding and the rider’s launch style. If the clutch type is a slipper, it’s normal for the friction material to wear-out sooner since it’s function is to allow the plates to slip past each other under high engine-braking loads during downshifts. Some friction materials do better than others regarding wear and engagement smoothness, just like brake pads.
Sometimes engagement problems begin after you’ve just replaced your worn-out stock clutch components, upgraded to an aftermarket clutch or changed to a slipper clutch.
The key to smooth engagement is controlling the frictional force developed between the smooth plates (that are driven by the engine clutch hub) and the plates that contain friction material (that drive the rear wheel through the clutch basket.)
The amount of force developed between these plates is controlled by the stiffness of the clutch springs, specifically by the amount of preload on these springs. When the clutch is fully engaged, the friction force developed between the plates needs to be greater than the engine’s applied torque to prevent slip. About 430 lbs is needed on a stock superbike.
When you pull-in the clutch lever, the hydraulic pressure applied to the slave cylinder overcomes the spring’s preload and progressively reduces the force pushing the plates together until they begin to slip. During this time the dished plate(s) in the stack act to provide a progressive reduction in the inter-plate force as the plates separate a few millimeters and you get full disengagement.
When you engage the clutch the opposite occurs. The reduced hydraulic pressure on the slave cylinder allows the push-rod to move the spring-loaded pressure plate toward the plate stack (a millimeter or so) until the plates begin to touch. Keep in mind that when you move the lever you are changing the POSITION of the pressure plate. You have only indirect control over the forces between plates.
The forces between plates is controlled during this transition (between disengaged and fully engaged) by a dished plate that is included in the stack to smooth this transition. This plate acts as a spring (pushes back with a force) when it gets flattened between adjacent plates by the movement of the pressure plate.
So, the force pushing the plates together first come from the smaller force produced by flattening the dished spring plate, and later, a much greater force produced by the preloaded clutch springs.
The higher the height of the clutch pack, the greater the clutch spring preload. So, as the clutch pack friction material wears-out, the pack height gets shorter, until the force between plates is insufficient and the clutch slips, at first under high torque conditions such as at launch, and later even when the lever is not pulled at speed. Time for a new clutch.
This is also the cause of the annoying phenomena of clutch “judder” such that when you release the lever, and while the spring plate is being compressed, the clutch springs can’t develop a sufficient force to prevent slipping so the plates slip, grab for an instant (causing vibration-induced slip,) grab, slip and so on, until the slipping stops as the engine torque is reduced when the bike acceleration eventually drops-off.
Here’s the Physics behind it. The friction force developed between two surfaces depends on whether the surfaces are sliding past each other or not. For a given amount of force pushing any two surfaces together, less frictional force will develop between sliding surfaces, than between surfaces that don’t. Once surfaces are together it takes more force to get them to slide than to keep them sliding. One they begin to side, however, they’ll keep sliding unless you push them together harder.
It’s these alternating higher-lower friction forces that cause the vibration that you perceive as judder. Sometimes adding a second spring plate to the pack will help to damp-out certain vibrations, so Ducati specifies a different number of flat plates, dished plates, plate thickness and stacking sequence for different models. The common spec however is stack height. Ducati clutch packs are stacked to 38mm ± 2mm.*
Here’s some examples:
Haynes Manual: 748, 916, 996
7 friction plates - one curved plate with two friction surfaces
Minimum friction plate thickness = 2.8mm
2.0mm plain plate #1
2.0mm*plain plate #2
3.0mm friction plate #1
1.5mm dished plain plate (convex side facing toward you)
3.0mm friction plate #2
2.0mm*plain plate #3
3.0mm friction plate #3
2.0mm plain plate #4
3.0mm friction plate #4
2.0mm*plain plate #5
3.0mm friction plate #5
2.0mm plain plate #6
3.0mm friction plate #6
2.0mm plain plate #7
3.0mm friction plate #7
2.0mm plain plate #8
pressure plate (line up marks)
38.5mm plate stack height
Haynes Manual: 916SP, 916SPS, 996S, 996SPS
8 (thinner) friction plates - two curved plates with one friction surface each
Minimum friction plate thickness = 2.3mm
1.5mm dished plain plate #1 (convex side facing toward you)
2.5mm friction plate #1
1.5mm*plain plate #1
2.5mm friction plate #2
2.0mm plain plate #2
2.5mm friction plate #3
2.5mm friction plate #4
2.5mm friction plate #5
2.5mm friction plate #6
2.5mm friction plate #7
1.5mm plain plate #2
2.5mm friction plate #8
1.5mm dished plain plate #2 (convex side facing away from you)
38.0mm plate stack height
Ducati Service Manual: 998
6 friction plates - one curved plate with two friction surfaces
2.5mm*plain plate #1
1.5mm plain plate #1
2.5mm*plain plate #2
Stack Height
A too-high overall thickness of the plate stack will cause drag between plates when the clutch is disengaged making it difficult to select neutral when the bike is stopped.
The last 2mm steel plate can be interchanged with a 1.5mm curved plate facing away from you if you want to adjust the stack to get the 38mm stack thickness, or if you want a more progressive, soft clutch engagement.*A commonly-used substitution that adds an additional spring plate to the stack.
Any of the steel 2mm plain plates can be exchanged with 1.5mm plain plates to reduce stack thickness or increase stack thickness as needed to achieve your desired overall height. You will see the need for this as friction plates wear, so keep your steel plates from pervious clutch replacements as spares to be used as height adjustments later. The 2mm and 1.5mm steel*plates only need replacing if they’re scored or warped.
Hope this helps.
Old 28-Feb-2004, 19:53   #18
wow
give me a couple of days to get my head round that lot and i'll let you know.
thanks for all your help.
Old 28-Feb-2004, 20:05   #19
paulmort paulmort is offline
Mood: Blooo Duke gets red heads
Ferg Shazzam
Im still lernin wot the left handle bar lever is for
I'll stick to Nelly doin it for me, and me riding
This muppet today, had steer in faster than Rossi's.
When Neil measured my tyrpe pressure thingies, had 'bout 12 - 15 psi in front and plus 40 in rear.
Pumpin up to some manual "tyre pressure recommended results" saw me have a new bike
So then, bak to thread, when you found out the simpleton's guide to slippers ( for me) and it can be put in 5 bullet points. then I'll unnerstand, til then, over to you guys and gals
mort
a perplexed, bamboozled and utterly ignorant mort
Old 29-Feb-2004, 11:46   #20
I put it back together last night as plate order from shazaam, and i think something is bent or squew. the clutch centre when done up tight doesn't spin quite true. when the whole thing is back together i can feel the clutch slip and then grip just by spinning it by hand on the biting point. I can't imagine that the gearbox shaft could be bent so hopefuly that only leaves the clutch centre not being on true. i will have to pull it apart today again.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:37.
