Old 25-Apr-2004, 08:25   #11
marko marko is offline
marko's Avatar
Mood: happy
I agree the Abba stand is a good idea, as I see it on most bikes they fit in the swinging arm spindle. On the 749-999
the swinging arm spindle has only got a very small hole in it, if the collets don't fit there where do they fit ? in the frame tubes, which is not an ideal place.
Old 25-Apr-2004, 13:11   #12
chris999 chris999 is offline
Mood: red and proud !!!!
they do fit perfectly
Old 26-Apr-2004, 10:03   #13
bazzer sps bazzer sps is offline
Yep, they do fit ok i must admit i was not sur at first if the amount of overlap on the nut (lh) was enough to hold it securely but it does even after rocking the bike.
Old 26-Apr-2004, 16:29   #14
Ned Ned is offline
I had the same thing happen, except I was more worried about the RHS. Maybe a little spacer inside the RHS cup, to stop the little ring disappearing inside... I emailed Abba.
Great stand tho, once you've worked out how to set it up. Solid as a rock.
Ned
Old 26-Apr-2004, 18:49   #15
why not do what it says in instructions and silicon sealant the adaptors in place..-
to stop the ring disappearing inside....
Old 27-Apr-2004, 16:41   #16
Ned Ned is offline
reading the manual is an admission of defeat... it's a bloke thing ;-)
here's what abba themselves had to say:
"The 999 adapter we have not had a problem with before I understand that the adapter doesn't stick out the standard cup on the stand which makes it a little harder to see when fitting the stand to the bike but when the stand is on and nipped up in its normal mode there is no problem. "
Ned
Old 27-Apr-2004, 16:53   #17
never heard of the 7 P's
my other half is always messing things up-she doesn't read manuals either....
thats a chick thing !!!!!
Old 02-May-2004, 21:39   #18
dismay dismay is offline
see market place
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:47.
