Old 21-Jan-2009, 10:06   #11
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
Originally Posted by paynep
Or don't crash.................oh, it's for Jimbers isn't it !
Harsh
Old 21-Jan-2009, 10:34   #12
Originally Posted by Steve GD
How about wiring it in series with the run/cut-out switch? Would that not be the simplest way to do it?
The reason I wouldn't do it direct like that is that circuits like the Ignition can draw 7 to 10 amps and unless you know what the tilt switch is rated at may not be a good idea, if its anything like the one on my TL1000S it will not be designed for that sort of current as it only needs to spply an interupt signal to the ECU.
Hence my suggestion to put a relay in series and interupt the relay with the tilt switch
Old 21-Jan-2009, 13:44   #13
Bikes: 916 Strada
Chaz's Avatar
Thumbs up
in that case I would wire it in on the earth side of a relay coil, so that when tilted the relay will drop out, I would then feed the power for either the fuel pump or Coils through the relay contacts so that when the relay drops out the feed is cut.
I would also fit an over ride toggle switch on the dash just in case
Done that today Kev all seems to work ok, Thank's.
Old 21-Jan-2009, 14:15   #14
Did you go with a Over ride switch or choose to do with out, as its me riding my own bikes I would go with one, but if its someone else riding my bike I may choose to do without
Old 21-Jan-2009, 14:56   #15
Bikes: 916 Strada
Chaz's Avatar
I went without one, keep it simple.
Old 21-Jan-2009, 16:31   #16
couchcommando's Avatar
Mood: ooooh
Get Jimbers to wear a lanyard round his wrist to cut the engine, not when he falls off but when he selects 1st gear. Cuts out the messy bit and you can always throw the bike off a building for the full effect too
Old 21-Jan-2009, 17:04   #17
Bikes: 916 Strada
Chaz's Avatar
Stop picking on Jimbers! he's assured me that he's far more focused this session, well I think that's what he meant [quote] "No more of those silly low speed crashes for me I'm determined to be much faster this year"
Old 21-Jan-2009, 17:26   #18
jimbers45 jimbers45 is offline
jimbers45's Avatar
Mood: Faster!!!
Arse! ....you lot won't be laughing with my front wheel lodged deeply where the sun dont shine on my way to the gravel trap!
.....and this override switch.....does it work for fear and incompetence and do they sell them at JHP?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:39.
