Old 30-May-2004, 21:48   #11
nathanhu nathanhu is offline
nathanhu's Avatar
Mood: head down
try taking the clutch slave off and get wiggling
:P
Old 30-May-2004, 21:52   #12
nathanhu's Avatar
Mood: head down
just kidding with the - :P
not easy to do
but it helps to take the rear wheel off so the chain can run a little untrue and you can twist the chain and the front sprocket out the front
Old 30-May-2004, 22:00   #13
dave w dave w is offline
dave w's Avatar
Mood: My K5 Rocks !!!!
Nathan..... removed clutch slave...... bloody wiggled for ages.... rear wheel removed..... no joy gave in and split the chain..... You must have more patience than me !!
Old 30-May-2004, 22:19   #14
You dont want to shorten the wheelbase, makes the bike very unstable in long corners...
I am not only fitting a 38 rear, i am also going to move the wheel further back to achieve 500mm between the swingarm pivot and the wheel centre.
Old 30-May-2004, 22:36   #15
nathanhu's Avatar
Mood: head down
andy
very true that the longer swingarm makes for a more stable set up
but
more stability = slower turning
you speak off a instabilaty in long corners, harder rear spring may help
Old 30-May-2004, 23:27   #16
the reason im doing this is because j hackett says do it....must be something in that?
( incidently its the same for the 998etc aswell as the 999, just cheaper and easier to achieve on the 999)
Old 31-May-2004, 10:58   #17
nathanhu's Avatar
Mood: head down
andy ive just got back from Assen with my bike and a 03 999r both with a smaller front sprocket and the then longer wheel base as i left out the 38 tooth rear , my 999s had a hard time turning on the über fast back section as i was still using a steep head angle , so i put it back to standard angle and fitted the 38 rear and the bike was a lot less effort to turn at high speed(over 240 kph)
ok 100% stable it wasnt but at high speed and 2 meters behind another bike the turbulance from the bike infront was the greatest problem to my instability!!
Old 31-May-2004, 12:40   #18
dave w's Avatar
Nathan.... you must be doing something wrong..... the bikes should be behind you not infront !!!!!!
Old 31-May-2004, 12:41   #19
Interesting, did you ever measure the length your pivot to wheel centre was changing from/ to/between?
Old 31-May-2004, 13:11   #20
nathanhu's Avatar
Mood: head down
nice one dave
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:53.
