Old 17-Mar-2009, 09:05   #11
phillc phillc is offline
Bikes: 996 race bike
Mood: Almost over it.
Certainly applies to the Monster range as they went to a 25mm rear spindle in 2002
Which is why I ask about whether 5 spoke ally wheels (from say a 2002 900ssie or a 2003 1000ssie) would fit fit a '98 900ssie swingarm. Perhaps there are different size 5 spoke wheels (SS vs Monster) just to confuse things further......
Old 17-Mar-2009, 09:37   #12
I will be able to confirm later when I get home if the rear 5 spoke from a 2002 900SSie will fit the earlier arm as I have both arms in the workshop and will be able to compare the spindle diameter as well as the width across the inside of the arm.
Old 17-Mar-2009, 09:41   #13
Thanks Skids.
I can confirm that the front spindle we have is 25mm and the rear 17mm.
Old 17-Mar-2009, 10:35   #14
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
Skids - as far as I can see, the earlier 900ssie arm is the same as 800 and 900 Sport steel arm. And 5 spoke wheels fit them cos my 800 Sport road bike is thus equipped atm (although not for much longer).
Find some S4 wheels - I've seen S4 wheels pop up on eBay regularly and Jim at Bike Enders has them in from time to time too. 900S, 800S 750ssie 3 spokes (although the 750 rear is a 4.5" rim) will also fit because I used them for a while until I got some more 5 spokers.
http://www.twpd.co.uk/pictures/800ss250306-1.jpg
Phil - does your bike have the underslung rear caliper?
Old 17-Mar-2009, 19:20   #15
Later 2002 900SSie curvey arm has a 17mm diameter spindle and 240mm gap between the left and right sides measured at the spindle position, this is exactly the same as the earllier 900SS alloy swingarm that I also measured
As Nigle said try giving Jim at Bike Enders a ring in Romford 01708 455530
Old 17-Mar-2009, 19:24   #16
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
Don't think S4 wheels will fit they have 25 axles?
Old 18-Mar-2009, 00:21   #17
Well there must be some variability in them then cos I have two! And they fit. As do ST4 wheels. I guess Ducati had been playing with spare parts bin!
Old 18-Mar-2009, 02:02   #18
Our latest advertisers seem to have some 5 spoke MArchi's
http://www.v-duo.co.uk/parts.html
F
Old 18-Mar-2009, 07:02   #19
Yep, sounds like it! Could be a bit pot luck then.
Thanks for all the tips and help gentlemen.
Old 18-Mar-2009, 07:03   #20
F
Thanks Frank. I have contacted them about these wheels.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:12.
