Old 20-Aug-2009, 23:07   #11
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
You would need someone with the right kit to measure cylinder head temp'. It's normal to run rear pots slightly rich to keep them cooler when doing custom maps. However, I do not think this is the cause in your case. I am sure you have either air or water in the fluid. Brakes are simple....they really are and so are the causes of them being broken.
Old 20-Aug-2009, 23:24   #12
Cheers M8. I'll start by flushing the rear brakes through completly with new fluid.
Old 21-Aug-2009, 11:00   #13
Ray Ray is offline
Ray's Avatar
I've had me 998 boil up it's rear fluid a time or two, I do tend to use the rear brake quite a bit.
A fluid change could well cure it, if the fluid is old it boils more easily as it's hydroscopic and the increased water content lowers its boiling point.
Brake fluids have a dry and wet boiling point. The wet is usually a lot lower, in some cases an couple of hundred of degrees lower.
Ray.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:10.
