Old 13-Jun-2011, 16:44   #11
Originally Posted by MJS
Is it really necessary to lock the cams? Surely if they move when you take the old belt off, it's just a case of lining the timing marks up again and making sure there are the right no. of teeth between each mark?
The testiclestretcher engine does not have timing marks, so when the front pot is at TDC on the firing stroke, the valves are closed and relaxed, but the vert is partway down the bore on its induction stroke and the wheels move considerably under spring pressure.
So mark the wheels and the belts, then transfer those marks to the new belts.
I then use a cheapo mic with freebie software to measure the frequency, at TDC, firing stroke, on each cylinder.
Old 13-Jun-2011, 22:57   #12
And on the Testastrettas you are supposed to loosen the cam pulley bolts so that they can move freely when tensioning the belts with the cams locked in position, so good fun without any timing marks
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:32.
