Old 04-Jul-2011, 18:31   #11
Wondering what the air gap is on the ignition pick-up coils. Also be interested if there reading changes when they are hot after running the engine for a period of time. At 97 ohms they are already a bit on the low side
Old 04-Jul-2011, 21:47   #12
ells ells is offline
ells's Avatar
I missed the trick of letting the bike stand running to get hot and then re-reading the pick up resistance. Hoping it will be running AOK for Pembrey
Old 04-Jul-2011, 22:25   #13
Today at Cadwell I was in the holding area, I noticed the idle revs were down from normal. Pulled the vert plug lead and the engine stopped. On part throttle it was running on 2 but not quite as crisp as it usually is.
Compression test revealed front pot 25psi down on the rear pot. So I took the head and barrel off, signs were running very weak. Then I found a large split in the carb rubber right under the Jubilee clip.
Better to find on a TD than waste a race weekend tho'.
Met a lot of faces today for the first time, good banter with everyone.
Old 05-Jul-2011, 20:23   #14
paynep's Avatar
Mood: Wet wet wet
You'd think that with all these problems with 17 year-old wiring, diaphragms, mixture screws, igniters and the like, you would get more people out on the 9-or less year old 620s.......
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:09.
