Old 03-Jul-2004, 13:27   #11
Reaper Reaper is offline
I've just fitted a quick action throttle I bought from:
www.extremebykesportz.co.uk
It works very well - feeling much more direct and reducing the required rotation from over 90 degrees to around 65 degrees (sorry to be vague, but I've nothing to measure this with).
The new throttle comes with two cables, but I managed to fit it retaining the original Ducati items - saving the chore of splitting the airbox. This required making two small collars to locate and hold the original cable ends in the new housing. I may fit the new cables at a later date.
The new throttle also comes with a choice of three cams; approximately 47mm, 53mm & 61mm in diameter. I guessed and fitted the 53mm cam to reduce rotation down to 65 degrees. For reference I measured the stock Ducati cam at 45mm.
As the new throttle is a non-Ducati item it did require a few minor modifications to get it to fit properly; eg filing about 0.5mm off the mating faces of the housing so it clamped securely on the Ducati handle bar. All in all, it took about 3 hours to fit and sort.
The throttle cost £150 inc VAT plus £8 delivery.
Examining the now redundant Ducati throttle showed my earlier attempts to reduce the play in the cables had merely resulted in stretching the locating holes in the original (soft plastic) cam.
R.
Old 03-Jul-2004, 15:46   #12
Well done mate. any piccies?
Old 03-Jul-2004, 17:17   #13
I'll try to take some pics and post them this weekend.
Meanwhile, if you want to see the quick action throttle itself, go to the extremebykes website and look under accessories.
R.
Old 03-Jul-2004, 17:29   #14
Maybe if a few of us order the throttle bodies we can get some discount...how manys interested.... i am
Old 03-Jul-2004, 17:48   #15
Sorry for crap photo - but you get the idea.
R.
Old 03-Jul-2004, 18:40   #16
wait a while though, i know pro twins do the single cable jobbie, dont know how much though.
Ive got jhp on the case, dont know how much though.
The corse item is going to be £200 ish.
The one reapers done is £158 + fitting it for the non mechanicals.
I think there is quite a bit of money to play with there re the jhp option.
But, by all means lets start a list to offer up for discount to whoever.
Andyb
Karl
Old 03-Jul-2004, 20:44   #17
nathanhu nathanhu is offline
nathanhu's Avatar
Mood: head down
996 gas
found this pic at home
[Edited on 3-7-2004 by nathanhu]
Old 03-Jul-2004, 20:52   #18
Whos bike is that mate? what else do you know about it?
Old 03-Jul-2004, 21:29   #19
everton
Andy mate. Keep us posted on this one..........let us know what you end up doing.
You must be keeping that R pinned if you're finding the throttle rotation a problem.
Must come from wringing the life out of the firm's Pan-Europeans
[Edited on 3-7-2004 by everton]
Old 03-Jul-2004, 22:05   #20
dave w dave w is offline
dave w's Avatar
Mood: My K5 Rocks !!!!
Dave its all in the wrist mate !!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:15.
