Old 25-Feb-2012, 23:12   #1
steeevvvooo steeevvvooo is offline
steeevvvooo's Avatar
late notice panic questions
Do I need the following to race. If the answers are in the regs then apologies, but I'm not at home and they are playing on my mind!!
1) Can I have a non-mainentance-free battery? I.e. One that is not sealed for life? I've fitted one today, but then realised there is an overflow and it might leak if I crash
2) Do I need a rear brake (I don't use one when on track really)? Looks like the master is broken from the slow speed off at Oulton.
3) Do I need to have a rev counter to race (I know I SHOULD have one to watch revs)? I can have one fitted to noise test hanging loose, but I've broke the bracket so can't fix it to the yoke at the moment.
Sorry for the stupid questions, but I have seriously limited time before Brands and would rather spend time and money on stuff like a good service if the above bits are not necessities to meet regs.
Old 25-Feb-2012, 23:32   #2
848spence 848spence is offline
Bikes: Ducati 848 and 583 dd race bike
848spence's Avatar
Quick answers
1) doesnt matter
2) It has to work to meet ACU regs
3) Would have to read ACU regs
Old 25-Feb-2012, 23:36   #3
Cheers. Thought that might be the case. Looks like I snapped the plunger off the rear master cyclinder but should be an easy replacement job. Recon I'll try and get a bracket made for the speedo anyway just in case, but wasn't sure.
Old 26-Feb-2012, 09:40   #4
1) Battery Breather / Overflow pipe should go to your catch tank/Bottle
2) Rear Brake needs to be working, I bet you will use it if your front brake fails
3) Its not a requirement to have a Rev counter, but without one it will make noise testing awkward and will be hard to tell if your bike meets the ACU legal noise limit
Old 26-Feb-2012, 10:32   #5
Jolley Jolley is offline
Bikes: 959
Jolley's Avatar
I didn't!... Didn't even enter my head! I just threw it into the corner and prayed! To my mind the rear brake doesn't even exist.
Old 26-Feb-2012, 12:10   #6
And when there is a bike right in front of you hard on the brakes at the end of a fast straight, would you just run into it, or try and scrub some speed off with the back brake
Having been in that position I know what I did and although I never use the back brake under normal race or road conditions on that occasion I did and it slowed me enough for the two bikes in front to tip in the corner and for me to carry straight on. At the end of the straight we were probaly around 130 to 140 mph
Old 26-Feb-2012, 15:13   #7
ok, I'll buy a new master cylinder. The rev counter was just a dodgy connection so think I've fixed that, and will run the breather for the battering in with the fuel breather pipes
Now need...
- number boards (seems these are available in the paddock from searching old posts?). Seems the ACU regs are pretty specific so not sure I want to risk ordering some online in case they're not right?
- Couple of bolts and clips
- seal the exhausts better where the link pipes meet the collectors
- oil and filter change
- Dog tags
Still feel like there's lots to do, and will probably need to take time off work to get it all done as I'm at a wedding all next weekend
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:32.
