Old 25-Aug-2004, 14:18   #11
RickyX RickyX is offline
RickyX's Avatar
Doh.........I thought that was the available ranges of adjustment, not the standard settings...
Large appologies for stupidity.
R
Old 25-Aug-2004, 14:28   #12
I'll let you off this time Ricky as it isn't made that obvious and to those unfamiliar with Ohlins would probably make the same assumption as you did.
I think you will find most of the Ohlins damping ranges have 20 to 30 clicks, 12mm of preload on a 6.5kg/mm spring gives 78kg of preload which sounds about right to me as a starting point.
I know that Ohlins forks have 18mm of preload available as I rebuilt Dallas's set on his R1 prior to Cadwell TA2.5 so looking at the fork pdf helps give the game away.
Old 25-Aug-2004, 14:55   #13
desmojen desmojen is offline
Mood: DOH!
Originally posted by skidlids
Well you can't blame him for that, he had reason to moan.
I was the oik in the TT T-shirt, will hopefully get introduced properly next time we meet.
So Hi for now,
will you be at Popham
Depends what time I can skive off work!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:57.
