Old 08-Nov-2004, 20:03   #21
Originally posted by Glyn
i wouldn't want to do this for a living
neither would I!!!!
Gissa job?
Old 08-Nov-2004, 21:34   #22
748mart 748mart is offline
I have found connecting devices via crossover cables can cause problems due to LAN speeds not being negotiated correctly. I would try setting the LAN cards on both machines to say 10mb/s half duplex or get hold of a cheap hub. A cheap hub should cost less than PC world charge for xover cable, 15quid ish.
The cable must be working in one direction as your are picking up packets from 'kids pc' on your PC. If you reverse the cable & same happens then cable should be OK & probably a duff LAN card.
Old 08-Nov-2004, 21:48   #23
Glyn Glyn is offline
Glyn's Avatar
Mood: st2......we can rebuild
:b ouncy:
have just installed a new protocol called netbuei or summit like that and instantly have a home network
Old 08-Nov-2004, 23:53   #24
Glyn's Avatar
i found a page on the web that told me netbui is often beter for cross over n/work than tcp/ip on its own also that netbui is no longer installed as standard under xp and that you have to copy the files manually into the right folders on your puter
Old 09-Nov-2004, 00:06   #25
Just curious, can the machines now ping each other?
Old 09-Nov-2004, 13:54   #26
Murray Mint's Avatar
You cant ping another machine if your only using NETBUI as the only network protocol, ping is only for IP.
One thing to remember is that you wont be able to use internet conection sharing if you only use NetBUI.
Murray Mint
Old 09-Nov-2004, 20:58   #27
Glyn's Avatar
i can ping
have still got tcp/ip ticked though
and have just tried unticking the netbui protocol and connection is still good?
so maybe it wern't that after all
god knows.
but its all happy at moment, and when my lad gets home from twi kon do were going to have a bit of a death match
Old 09-Nov-2004, 21:08   #28
so you added netbui and now IP works ...
And to think my career is based on this technology !!!! Sheesh!
Someone get me out of this industry!!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:06.
