Old 21-Feb-2005, 16:35   #21
Twinfan Twinfan is offline
Twinfan's Avatar
I'll get mine on here later...
Old 21-Feb-2005, 17:22   #22
jobr jobr is offline
Mine is an 04 749s purchased November 2004 last six digits of the frame number are 003690.
Old 21-Feb-2005, 17:59   #23
I've never owned anything later than a 2001 ST, but on the these bikes the brake and clutch lever have a large grub screw near the pivot. It looks for all the world as if you can use this to adjust the lever span but this is a mistake, because if you adjust it too far the master cylinder piston doesn't return far enough to let brake fluid return and the brakes effectively 'pump up' until they lock.
Since, somebody mentioned 'grub screw' earlier on in this thread could it be a similar problem?
I know the 749/999 have a different master cylinder and I've never really bothered to look that closely at them so I could be talking rubbish
Old 21-Feb-2005, 18:10   #24
guest1 guest1 is offline
Front brake has "dial" for adjustment so the grub screw theory may or may not be relevant.
I know on the superlight it had a small plastic insert between the adjuster and the cylinder plunger.
Old 21-Feb-2005, 19:24   #25
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
Your getting confused with the span adjuster and the screw that takes up slack in the lever before pumping the fluid.
Old 22-Feb-2005, 01:12   #26
V2 PETE V2 PETE is offline
V2 PETE's Avatar
Mood: to ride new metal !
my details are
registered march 2004
binned feb 2005
frame no ends in 002616
interesing to see tf's conclusion on the matter...!!!
Old 22-Feb-2005, 08:39   #27
pedro pedro is offline
pedro's Avatar
Mood: r
i can see d.i jack frost getting in on this one?
Old 22-Feb-2005, 08:49   #28
V2 PETE's Avatar
you may have radials on yours ..
but you may have the same lever and master cylnder.....!!!!!!!
you say you of to spain too....!!!!
are you the next guy.........
Old 22-Feb-2005, 08:52   #29
V2 PETE's Avatar
british hospital food is one thing...!!!
spanish hospital food , well thats another.........
Old 22-Feb-2005, 09:35   #30
Twinfan's Avatar
Was yours a front brake problem, if so really scared now as yours is only 8 frames away from mine
Yep, Pete has had exactly the same problem as me. Front brakes locked, bike went down. I forgot to get my frame number last night, so I'll have to do that later.
Scary stuff huh?
My thoughts exactly...
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:11.
