Old 09-Mar-2005, 23:28   #21
DSC Member AK AK is offline
AK's Avatar
Tim,
got some advice that we are doing to ours, prob the same as you
Old 09-Mar-2005, 23:34   #22
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
Don't think I'll need to do a lot to mine.
Some heavier oil should do the trick...
Might have to stack some shims in there too, but let's see how the test day goes.
Where d'you buy the shims from anyway?
Old 09-Mar-2005, 23:36   #23
AK's Avatar
I am revalving & shimming mine
Alan
Old 09-Mar-2005, 23:39   #24
monstermob 998's Avatar
we use to use old 10p pieces in the front forks of yamaha RD's!!!
Old 09-Mar-2005, 23:48   #25
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
A shim shop of cource
Old 10-Mar-2005, 00:01   #26
Or is that a Corse shim shop !!!
Old 10-Mar-2005, 00:17   #27
I have an Ohlins rear but the front there's not a lot you can do. I've had Hyperpo springs and 20 weight oil in mine sorted by Big Al.
[Edited on 10-3-2005 by phoenix n max]
Old 10-Mar-2005, 21:45   #28
Zimbo the Mechanic Zimbo the Mechanic is offline
Depends on the forks you've got. If they're Showa they can be revalved (racetech is probably your best bet) but if they're Marzocchi you're stuck with springs and oil weight adjustments. You can tell showa from Marzochi easily by the caps on the top, if they've got a 17mm hex they're Showa, if they're much bigger (mid 30s mm I think from memory) they're Marzocchi.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:48.
