Old 16-May-2005, 18:22   #21
Originally posted by HW
Mine looks like this. I can move the pipe with my finger so I know it is not trapped.
That's how mine are, you can see the fuel lines dissapear up inside the tank (kind of) and not resting on the head as such
Old 16-May-2005, 18:24   #22
HW HW is offline
That's right. In Everton's reply above he talks about them not being able to go over the plug connector because it fouls. There is clearance up under the tank there so it does not seem to be tight.
Maybe some fuel lines are shorter than others so they cannot go into the recess? (not all fuel lines created equal?)
Old 16-May-2005, 18:27   #23
everton
Being a 999R it probably has another 9mm of fuel line
Old 16-May-2005, 20:22   #24
khu996 khu996 is offline
khu996's Avatar
Fantastic diagram Henry, I can't move mine in too much because it'll also foul the connector. Anyway, not had any trouble with it, so perhaps I can leave it as it is.
Old 16-May-2005, 20:24   #25
HW HW is offline
Actually ... it was Everton who posted the diagram but not to worry.
Old 16-May-2005, 20:40   #26
khu996's Avatar
Oops!
Was reading too fast (thats my excuse anyhow!).
Big up Everton for the diagram then!
Old 16-May-2005, 20:52   #27
Carbon749's Avatar
Mood: I own a flame thrower
Just to add to the apologies ..... when I gave advice on the routing of the fuel lines I "forgot" that my tank is not standard and that the lines may sit differently.
All that said, the fuel lines should not be trapped between the rocker cover bolts and the underside of the tank, they should run inboard of the bolt heads which should give them a little free play between the tank and rocker cover.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:13.
