Old 19-Jan-2013, 13:11   #1
batesy2 batesy2 is offline
Bikes: ducati 620ss racer,aprilia rsvr mille,husqavarna 125 crosser
Mood: easy going,love to laugh,fairly competetive
Question camshaft gears/timing ?
Hi Guys, I keep hearing about an advantage to be had by optimising cam timing,I understand the principle but have no idea who can do this mod and where the required parts can be got,
Please enlighten me
Batesy
Old 19-Jan-2013, 14:22   #2
Brian you shouldn't need any parts unless somebody has replaced yout adjustable cam pulleys with fixed ones and they would only normally do that if they have been degreed in with fixed offset woodruff keys.
Old 19-Jan-2013, 16:19   #3
Hi Kevin,Thanks for replying,I think they are the standard ones but didnt realise they are vernier, Do you know the specs for setting them up ? I dont really have any issues with the way Doris runs but any extra is always welcome as the actress said to the bishop.
Old 19-Jan-2013, 17:45   #4
Best thing is to check what they are at the moment, if they are both identical the chances are they have already been done.
Different engine builders use different specs, some use standard others use something a bit different.
Two ways of doing it either on Cam lobe centres or at 1mm of lift on the inlet
Old 20-Jan-2013, 08:43   #5
SeeleyG50 SeeleyG50 is offline
Bikes: 500 Pantah, TT2, 749R, 944ssie, Rickman Kwak 1170, Yam 1200 Super Ten
SeeleyG50's Avatar
Mood: The Older I get the Faster I Was!
Just a note. The pulleys aren't vernier adjustable, they're just slotted. This means that they can be slightly fiddly to set accurately, so be careful & patient.
Also, in my experience, most will be different between cylinders & are likely to be some way out, so, as Kev says, if there identical and on the money, then they've been dialled in.
I've always timed using inlet opening (although inlet closing is the most influential timing point), but would say most tuners go with centreline figures. My 'issue' with that is that the centreline does not always correspond with maximum valve lift.
Whatever, get them checked, because it smoothes the bike out and if you play around with the timing a little, you may make a few gains
#33 Racing
Old 20-Jan-2013, 11:34   #6
bally71's Avatar
Mood: Inquisitive cat
been thinking about having a crack at this myself
apart from a couple of dial guages and a degree wheel thingy what other tools do you need?
is there someone known who makes the offset woodruff keys?
anyone got any good advice?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:36.
