Old 24-May-2005, 14:14   #21
Originally posted by uncledunnie
I ran 14/48 at Brands Indy and it would'nt pull over 8500 rpm in 5th and 6th on the relatively short start finish straight.
Maybe I should chop my legs off too.....
It wouldn't pull 14/48???? Wow, that's WAY short!
I'm going to run 14/46 there tomorrow and see how I get on.
Old 24-May-2005, 14:15   #22
Originally posted by fil2
not all............................some of us need a better top speed.....
I know it sounds funny me going shorter but I think that will give me more top speed.
And beautifully, it will also give me more drive off the corners
Old 24-May-2005, 14:16   #23
Although I'm only running a lowly underpowered 583 I was looking at running either 15/42 or 15/41 gearing, there should be plently of bikes in front for me to slipstream. But only one practice session that is going to be our timed quallifier there isn't a lot of room for to big a error.
Old 24-May-2005, 14:29   #24
fil2 fil2 is offline
fil2's Avatar
Mood: is it still wet
15/41 would be a good start for you kev...i was on 14/39..the ratio difference is 0.3........
but i'm changing mine to get more top speed...........
Phil
Old 24-May-2005, 14:34   #25
domski's Avatar
DESMO DUE GEARING CHART
Old 24-May-2005, 16:12   #26
As a reminder, on the straights almost all your power is being used to overcome aerodynamic drag so learn to tuck-in well to go faster.
Old 24-May-2005, 16:15   #27
Very good point - I have clipons and a nosecone to go on the bike. I'll be able to get right under it all.
Old 24-May-2005, 16:20   #28
domski's Avatar
Have you looked in a mirror recently??
...running away VERY quickly!!!
Old 24-May-2005, 16:21   #29
You can't run that fast Dom.
I'm so gonna kick you're ar$e.
Old 24-May-2005, 18:33   #30
TP - have you tried Mike at robsom racing ?
Mine arrived last week 2 days after ordering. I'm not sure if your bike and mine use the same sprockets though but worth a try.
Link below
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:00.
