Old 24-Aug-2005, 23:22   #21
DSC Member simonducati simonducati is offline
Bikes: Had 748,749, 848 and now a 1199 Panigale
simonducati's Avatar
Mood: Living the dream.
how Tight do I torque the mane nut too?
Old 25-Aug-2005, 00:21   #22
Fordie Fordie is offline
Regional Organiser - BHCN
Fordie's Avatar
Mood: Raring to Ride
The Alternator rotor to flywheel/starter clutch bolt is 13 Nm
The Alternator nut is 186 Mn
[Edited on 24-8-2005 by Fordie]
Old 25-Aug-2005, 07:58   #23
m1keyp m1keyp is offline
The reason that I mentioned the clutch tool is that you will see in the guide supplied by Keefer that they held the clutch to undo the alternator nut.
As yours is already loose you won't need one or removing the nut but you may for re fitting.
Good luck and think of us at Brno this weekend
Old 26-Aug-2005, 00:50   #24
Good luck and think of us at Brno this weekend [/quote]
I Did it, but its still not working…… so I went back to the clutch side and found that the engine is jamming. If I turn the clutch clockwise a bit and then try and start it it makes a bigger bang when it jams. I’m going to get in to it tomorrow and il let you no how I get on.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:20.
