Old 16-Sep-2005, 22:39   #21
duck duck is offline
duck's Avatar
congrats, i have an 04 749s fantasic bike, face lift model looks better still.
they are way overgeared, can't go lower on the front sprocket but supersrox do a tasty ally/steel stealth rear, only 39 + 42 tooth selection though
i always give the front coil a spray of wd40 when i get back whether caught out in the rain or not. prevention is better than the cure and all that....
if you fancy a bit more comfort on the wrists iang is looking to do a group order for cyclecat fully adjustable clipons saving £88 off the £276 normal price
Old 17-Sep-2005, 06:39   #22
Originally posted by BIG-G
Hugger ordered, will be looking for Termi's on ebay etc unless anyone selling. Do I get the system or end can and wheres the cat located?Do I also need chip with either. I also want most power mid range.
Who are the best aftermarket suppliers for goodies?
Also need idea's for a bigger/ doublebubble screen.
See ya
G
Good luck in your Ebay search for '05 Termi's,they are rarer than hens teeth.
You have two choices,the assymetric system,(A race can and front pipe),or the full 2-1-2 system.The latter will cost the thick end of £2.5K!
LeoVince,Akropovic do slip on cans,...not sure if they work with the catted front pipe tho.Cat free pipes are available from dealers for about £150.Then you will need a new CPU or Power Commander to sort out the fuelling.Either way,not cheap!
Dont be tempted to buy a system for an '03-04 bike.The bend on the front pipe is differant to clear the cast swingarm.
Not seen any aftermarket screens for the '05 bikes yet,although I hear that MRA make one.The '05 screen is a lot taller than the '04.You should be able to get MRA screens from HPS.
www.bikehps.com
Other goodie emporiums are,
www.casoli.co.uk
www.ducati9.net
Old 17-Sep-2005, 08:16   #23
BIG-G BIG-G is offline
BIG-G's Avatar
Mood: I started life with nothing and still have most of it left
KeefyB, thought I got up early but you get the worm.
Just watched Ducati get pole in Japan. Picking mine up 10am then on to the web to buy bits. Will leave pipes until spring and will look at MRA screen.
G
Old 18-Sep-2005, 18:35   #24
rtomuk rtomuk is offline
Mood: Fantastic
Don\'t buy e-bay termis !!
G
The only Termi's that will fit are 05 spec because of the new swingarm ! They are due out in the next few weeks ! Sorry to spoil your e-bay shopping but hey you'll spend a grand and they won't fit !! Hope this helps !!
Rob
Old 18-Sep-2005, 18:51   #25
Rob
Did'nt I say that?
Old 19-Sep-2005, 08:42   #26
BIG-G's Avatar
I'll start saving now to fit in the spring.
Who does the best deals on these.
G
Old 19-Sep-2005, 08:45   #27
BIG-G's Avatar
PS, do the Termi's fit both 749 and 999 or are the systems different.
I'll go for just the can and the pipe to get rid of the cat and will this run on the standard chip
G
Old 19-Sep-2005, 10:17   #28
Twinfan Twinfan is offline
Twinfan's Avatar
Slip-on (assymetric) cans are the same for all models I think. You can check the 2005 performance catalogue for the part numbers.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:27.
