Old 30-Sep-2013, 22:00   #21
knappers knappers is offline
Originally Posted by antonye
One is feed and one is return.
The pic you sent me, is that quick release push fit into the out and return?
This tank just has male spigots screwed into tank, fuel lines pushed on.
What about the other 2 protrusions? Seen a video on you tube looks like they're linked by a pipe but hard to see.
Old 30-Sep-2013, 22:01   #22
One is the overflow and the other is the breather
Old 30-Sep-2013, 22:16   #23
Thanks, So they can be connected breather run down to bottom of engine.
The feed and return, how are they set up? On this tank they are connected to single pipe before running to carb inlet. That's how it came to me.
It has been badly messed around with the wiring is really bad I'm surprised it runs at all.
So if i connect it up as is 2 into 1 to carbs in theory should work, carbs might flood / leak because of regulator?? Thanks
Old 11-Oct-2013, 22:36   #24
Trying to upload video to youtube, not having success.
Haven't done much more with it, had too many other things on.
3 munkeees under 3 1/2 doesn't help.
Try get more done next week, thanks for all the info so far.
Old 14-Oct-2013, 20:33   #25
I've managed (at last) to get a video on youtube, nothing special just its first run after putting it together.
Type in Ducati Bitsa first start
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:03.
