Old 13-Feb-2006, 10:13   #21
It still sounds to me like there is not enough current to turn the engine over.
Jump start it off your car Tonio - if that doesn't work then start looking at your wiring.
Old 13-Feb-2006, 10:33   #22
Tonio600 Tonio600 is offline
Tonio600's Avatar
Mood: What a wonderful world.
Message original : everton
Originally posted by Tonio600
I forgot to mention that to save some weight I got rid of most of the wirings which I thought were useless. So actually I've removed (ahem... cut) everything going to and coming from the dashboard.
Any idea?
Did you cut the really big important wire?
No no. Actually I only cut thin wires. And before doing so I checked where the wire was going to and coming from. I don't think I've done any mistake on that point, I may have but once again I don't think so...
Old 13-Feb-2006, 10:36   #23
Tonio600's Avatar
Message original : Scooter916
Sounds like the main ignition relay to me tonio, Mine did the same after beinjg on its side at donnington, There are t relays fitted if i remember correctly, Mine was yellow and i took it to a local motor factors and got a replacement for a fiver, Problem solved.
Ir is a common fault so well worth a check.
Glyn
I think the relay is working fine as I can hear it doing "clac" when I turn my ignition switch to ON/OFF... But I'll have a look at that if the battery is not the cause...
Old 13-Feb-2006, 10:37   #24
Tonio600's Avatar
Message original : TP
Yep, that's the only thing I can do for the moment. Tonight I'll take the battery off the car and will try like this. Will let you know what it does...
Cheers guys.
Old 13-Feb-2006, 12:56   #25
mjbayley mjbayley is offline
mjbayley's Avatar
Mood: Been Testing the 3 P's (Pizza, Pasta, & PERONI!)
Hi Tonio, ???????
going back to 'basics', have you moved or changed or taken off the main earth lead (the bigger black one), from engine to frame or frame to battery?
Mark (AntonyE's pit bitch)
Old 13-Feb-2006, 13:08   #26
DSC Member AK AK is offline
AK's Avatar
Tonio, if you cant get it sorted by Saturday, why not pop it onto a trailer & bring to the agm with you (I think you said you were going?).
There will be a lot of ducati "mechanics" there to help you.........
C
Old 13-Feb-2006, 13:30   #27
Tonio600's Avatar
Message original : mjbayley
Hi Tonio, ???????
Hi mate,
No problem there, I checked the earth lead in both places (frame <-> battery and frame <->engine).
Tonio
Old 13-Feb-2006, 13:32   #28
Tonio600's Avatar
Message original : AK and CK
C
That's an idea
May do that if I couldn't sort myself out before. That could be fun... A bottle of Muscat de Rivesaltes for the first one to find what's wrong with it
Old 13-Feb-2006, 14:15   #29
mjbayley's Avatar
He's another guess.
Does the engine 'spin' over with the sparkplugs removed?
If you have a 'leaky' float valve in the carbs, and you left the fuel tap on, you could possibly have filled the vertical cylinder with fuel.
Hence only turning over once.
Like I said just a guess?
Old 13-Feb-2006, 14:20   #30
Check the connections on the start solinoid aren't touching against the cylinder head.
If all OK there get a set of jump leads run one from the -Ve of the battery to s good engine earth, I find exhaust studs work well.
Then with the other jump lead connected to the battery +Ve prod the other end on to the starter motor connection, if you still only get half a turn I would suspect the starter motor but could also be a problem with the engine
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:04.
