Old 24-Aug-2006, 21:59   #21
domski's Avatar
I only use factory forks in my bike.
Old 24-Aug-2006, 22:01   #22
DSC Member AK AK is offline
AK's Avatar
which factory ones?
Old 24-Aug-2006, 22:07   #23
Scooter916's Avatar
Mood: Hmmm Conference season
Originally Posted by AK
which factory ones?
Charlie and his chocolate ones
Old 24-Aug-2006, 22:12   #24
domski's Avatar
You two are so nasty to me
Old 24-Aug-2006, 22:12   #25
Tonio600 Tonio600 is offline
Tonio600's Avatar
Mood: What a wonderful world.
Thanks for all the answers guys... I'm 99% sure the disc is fine. I haven't crashed yet so I can't see any reason why it would get warped... I had warped discs last year and the feeling was totally different...
I think my problems started when I did the 2 changes below (unfortunately I did both in the same time and so don't know which one could be the cause of my problem):
- fitted a 6.5kg spring to my Ohlins rear shock (instead of a 7.5) following the advice of a mate.
- fitted a pair of jacks (built by Rich @ Louigi Moto) to raise the rear of the bike.
Anyway I'm not tired, so I'm now off to the shed taking the forks apart, I need to see what's inside (I've even been suggested that they could be empty of oil in regard as how they behaved in static... ).
Old 24-Aug-2006, 22:38   #26
Zimbo16 Zimbo16 is offline
Zimbo16's Avatar
Mood: Feeling peckish
6.5kg sounds a bit on the light side for the rear spring Tonio, I'd have said 8kg would be about ideal. could you try putting the original spring back on and see if that improves it? I would have said raising the rear ride height shouldn't cause problems under braking particularly, of course I may be wrong though!
Whilst you have the forks apart, measure the springs - outside and inside diameters, free length, and also the length of the spacer tube. The springs I have may well fit.
Old 24-Aug-2006, 22:46   #27
Tonio600's Avatar
Right, a few things which may speak to you more than to me.
First, the lenght of the forks I was using at Cadwell, I have absolutely no idea of if it was "bottoming" or not...
The leaking left leg...
And finally, even if Dr AK is always saying "read your tyre you numpty" I never think about doing it. So I just had a look at the front tyre and I must reckon I've never seen it being so worn in the middle and with so many wrinkles...
And
Which still makes me think I've got a suspension problem rather than a brake problem. Off to the shed again, now I'm starting the surgery bit
Old 24-Aug-2006, 22:59   #28
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
Tonio are your forks always that mucky? only I'm thinking leaking fork seals?
Old 24-Aug-2006, 23:15   #29
Tonio600's Avatar
Yes Jon, the left leg is always leaking
Old 24-Aug-2006, 23:19   #30
Tonio600's Avatar
And finally what I found in the left leg:
Zimbo, dimensions of the left leg spring are 280 x 35 x 25mm.
That's it for tonight, after all Cadwell is in about 6 weeks
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:48.
