Old 09-Sep-2006, 22:38   #21
Zimbo16 Zimbo16 is offline
Zimbo16's Avatar
Mood: Feeling peckish
Originally Posted by Mr.R
Hi, 900 monster frames are basically the same as the 851/888 frame(sub frame differs but the shock will fit) 600's use a differant frame,so no go IMHO.
Steve
You may know something I don't, but as far as I was aware the carbed monsters use the same frame with just the swinging arm different (aluminium rather than steel) on the 900, and obviously designed to take the wider wheel. Shocks are identical and I have happily swapped shocks between 600 and 900 monsters without problems. The fuel injected monsters use a different frame, taken from the ST series, and have a different shock. The superlight as far as I'm aware is completely different as well, but I'm not an expert on them, just assuming they're similar to the SS frame?
Old 11-Sep-2006, 01:37   #22
jgriff jgriff is offline
jgriff's Avatar
They are the standard Marzocchi Duo Shock that is fitted to 1990 851, they are 330mm in length and will fit on 888's, and monster 900's. As a shock they are OK, but I replaced mine with an Ohlins DU440. But at Nattyboys prices you can't go wrong.
Griff
Old 11-Sep-2006, 07:49   #23
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
Cheers for that Griff..part label deffo says '851 racing' ??!!
Nat
Old 11-Sep-2006, 08:02   #24
Redsps Redsps is offline
Redsps's Avatar
With yesterdays incident nat I'll have to pass on one of these mate.
need the cash to get the bike sorted now.
cheers
Robin
Old 11-Sep-2006, 08:46   #25
jgriff's Avatar
I guess back then, they were "Racing" They are a good shock. Just Ohlins is better.
Griff
Old 12-Sep-2006, 16:00   #26
MonstaTom MonstaTom is offline
MonstaTom's Avatar
just finished fitting a t8 shock to my 97 m600 and the only thing you have to do is slightly slacken the banjo bolt on the top of the shock that connects the hose to it then tap it carefully through 180 degrees to clear the frame then nip it up again, job done ready for brands
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:26.
