Old 10-Feb-2006, 20:18   #21
khu996 khu996 is offline
khu996's Avatar
Keefer, the difference in opinion between you and Andy is still confusing me
But I'll try and clarify things tomorrow. Either way, I'll let you know.
Old 10-Feb-2006, 21:18   #22
Rick Rick is offline
Let us ALL know please
Old 11-Feb-2006, 14:19   #23
khu996's Avatar
Called GPR, they were too busy, promised to ring me back, but they didn't and now they're closed.
Anyway, rang ever faithfull JHP, who confirmed that the master cylinder bodies are the same, its only the levers that are different.
Hats off to Andy the techie genius! Looks like I won't be needing a new cylinder after all!
Old 11-Feb-2006, 17:45   #24
Old 11-Feb-2006, 20:24   #25
Originally posted by keefer
http://www.gprdirect.com/epages/GPRD...Catalog/1004/1
no great confusion
only Andy who has a different opinion.
give them a bell though. and after that I'm still up for the swap as mentioned above. cheers K
No confusion now then???
Old 11-Feb-2006, 21:55   #26
The master cylinder body establishes the distance between the piston axis and the lever pivot point, so the 19x18 and 19x20 bodies are different by 2mm.
Old 11-Feb-2006, 22:04   #27
Felix Felix is offline
Amazing the amount disinformation floating around...
As I said above the levers are NOT interchangeable. Yes, they'll fit but you'll seriously risk the malfunction of the master cylinder. As Shazaam says the distance is different between the two and that's why Brembo stamps them differently. Do you really think that Brembo would produce different levers if they were interchangeable? Just to be sure, I measured both a 19x20 and a 19x18 just now and it confirmed that they are different.
[Edited on 11-2-2006 by Felix]
Old 11-Feb-2006, 22:15   #28
OOOooooooooooooooooh a conflict of Guru's.............
Old 11-Feb-2006, 22:17   #29
Not really, Andy.
Old 11-Feb-2006, 22:34   #30
So are you saying all brembo levers are the same? and its by putting them on to a 19x 20 or 19 x 18 body is where you get the ratio difference?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:18.
