Old 24-May-2004, 17:32   #1
nathanhu nathanhu is offline
nathanhu's Avatar
Mood: head down
chillo how heavy are you?
i had this weave or pump at high speed so if you weigh over 85 kg(dry) then go for the new spring on the rear it worked for me and cost very little
Old 24-May-2004, 19:08   #2
jk2 jk2 is offline
jk2's Avatar
I have a 999S biposto spring (6Kg I think) which is too hard for the road - probably OK for track. Like new, £30 only!!ink:ink:ink:
Old 25-May-2004, 13:13   #3
chillo chillo is offline
chillo's Avatar
Nathan
i'm 80kgs ish
i was going to dial in a bit of compression to see if that helps then i might give the new spring a go
chillo
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:37.
