Old 12-Jul-2004, 09:44   #21
Mark11 Mark11 is offline
Hi 3narf,
Thanks for that, i will check your thread! and try that out.
I live west Hull in a village called Ferriby.
Mark.
Old 12-Jul-2004, 16:44   #22
Hello Again,
Can you give me a bit more info on where abouts the throttle sensor plug is and what it looks like.
Cheers Again
Mark.
Old 12-Jul-2004, 18:55   #23
iceneweb iceneweb is offline
Mood: i'm hungry
i had exactly the same problem on a 99 Sv650. the offending part was a split carb to cylinder head rubber. $90cdn later and it's running like a top again
Old 13-Jul-2004, 10:33   #24
Neil Murray Neil Murray is offline
Just a silly point, but there isn't an ignition cut-out on the injected SS, is there? Clutch interlock? Sidestand interlock?
I've had this problem on other bikes, and it was the result of the bike, at certain revs, hitting exactly the right vibration frequency to cause an intermittent fault. And then, of course, it got worse and worse.
Old 13-Jul-2004, 14:20   #25
3narf 3narf is offline
Bikes: KTM Duke 640
Hi Mark-
The connector is behind the LH fairing mount.
Give us a ring on 07734 506418 for more info!
PS My wife's mother lives in Brough...
Old 13-Jul-2004, 14:31   #26
Great thanks for that 3narf!!!
I'll have a look tonight, do you have to remove the fairing to get to it or see it?
Often drive through Brough, she's maybe heard me thundering past with my race cans on.
Mark
Old 13-Jul-2004, 20:15   #27
Bikes: KTM Duke 640
It's much easier with the fairing off and tank propped up. I changed my plugs today and cleaned aforementioned contacts; there's still a glitch around 3000...
Mother Outlaw is staying with us at the mo, seeing as her daughter was due to give birth today!!
Typical, she's always late...
cheers, A
Old 14-Jul-2004, 09:27   #28
Ok Cheers 3narf!!
Good Luck with the new baby!!
Mark.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:43.
