Old 20-Jan-2009, 22:46   #1
faith-healer faith-healer is offline
Caliper mounting brackets
The other day I spotted a pair of caliper brackets that allow 65mm calipers to be mounted to 40mm forks, on 'FleaBay'....
Of course now I want a pair I can't trace 'em....
Can anyone help,
....know where I can get them'
....know who makes them
............or whatever
Charlie
Old 20-Jan-2009, 23:39   #2
Not sure who in the UK does them
I take it this is what you mean
http://www.yoyodyneti.com/ProductInf...ctid=70.2005RL
Old 21-Jan-2009, 00:27   #3
Likewise, not sure of a UK supplier....you could try asking member Superlight3:
http://www.ducatisportingclub.com/pr...o=newpm&u=7523
These guys are VERY good however:
http://www.kaemna.de/cms_en/katalog....el&artikel=234
I'd recommend going for 4-piston calipers if you are upgrading, well worth it.
Cheers - Frank
Old 21-Jan-2009, 11:08   #4
Thanks Frank,
I've also been pointed at www.ducatisaarland.de but s**t they're expensive. The site is all in German too, no translator, but I managed to wade my way through it.
I've actually got a set of polished P4's off a 999 ( the only 900 miles from new). Just getting all the lines made up now in "Norn' Iron"
Old 21-Jan-2009, 11:24   #5
would it not be worth considering moving to the later non adjustable forks that already have the 65mm caliper mounts.
We have converted several front wheels to take the larger spindle by fitting new bearings and spacers, so all that is then required are the forks and spindle.
Old 21-Jan-2009, 11:51   #6
I know what you mean Kev' but Ive got two sets of Marzocchi forks (both 40mm spacing), one set with twin caliper mounts and one single. The twin caliper forks and my rear shock have gone to Maxtons for servicing (and new springs in the forks) so it will be cheaper to fit brackets.
I may even be able to get some brackets made up..... If I can get them done AT THE RIGHT PRICE then I may be able to get some extra sets done.....
Then other will benfit as well....
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:28.
