Old 10-Mar-2009, 04:54   #21
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Originally Posted by HUNT749
topitoo.
If you dont mind me asking whats causing your failures??
(just read that back sound like a therapist)
LOL
The first engine just seized on the M3 on the way to Popham (Crankshaft Oil Galley Plug/main bearings) 97yr
The second engine was newer, was looked after with regular oil changes every 3K miles, with good oil,
run for 2mins from cold etc although I did drop it at Brands, even though I managed to turn the engine off quick sharp. (main bearings again)
in both cases the crank was shot . . oil starvation, even though no signs of metal in the pickup filter
after a month started all over again, but if this one goes thats it for me.
TopiToo
Old 10-Mar-2009, 19:50   #22
RickyX RickyX is offline
RickyX's Avatar
My 748 motor went bang just like you describe on my first ever trackday back in 1998. It had 45K kms on it at the time......
Ended up just getting a s/h one to replace it - loads cheaper than a rebuild.
Have fun with your decision!
Old 11-Mar-2009, 15:03   #23
gordonparker's Avatar
Mine has 60K km and still going strong, perhaps I should have it checked over
Old 01-Apr-2009, 16:55   #24
HUNT749 HUNT749 is offline
Time for a update....
Sorry its bean a while but not had much time lately, As said before swingarm bolt was siezed so ended up cutting out to free frame and then cut swing arm to free from engine.
As you can see in the pics ,
Front cylinder shells have some damage but compared to rear cylinder look good , Rear is mullerd to hell crank is also worn quite badly so new engine needed rest ok so will sell of bits to help pay for engine and swing arm
Simon
Old 01-Apr-2009, 20:28   #25
Bikes: 748ish . .
Hello HUNT749
looks about the same as mine did after the stip down.
just another thought it is possible with this type of damage
the con rods will be shot too,
but I understand you can get them machined depending on damage,
or pick up a good set on ebay if thats the route you wish to take.
good luck
TopiToo
Old 01-Apr-2009, 20:47   #26
Hello topitoo,
I also think that the rods are shot as the surfaces are worn away quite badly . Was thinking about getting them machined but not sure yet on what to .
I know its a long shot but whats the difference in length between 748 and 916 conrods saw a crank and conrod assembly on fleabay and wondered ????
Simon
Old 01-Apr-2009, 21:08   #27
injected injected is offline
injected's Avatar
Mood: Blown away!
If you want to keep it as a 748 I have a good spare engine, freshly serviced, with oil cooler if you want it. Lmk
Old 01-Apr-2009, 21:12   #28
yes would like to keep it as a 748 , whats the history on engine as in age ,mileage etc and of course money required
just realised also 916 conrod and crank assembly wouldnt fit as stroke different isnt it!!
Simon
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:15.
