Old 03-May-2009, 23:38   #21
up the preload then
job for Tuesday
Old 03-May-2009, 23:43   #22
Originally Posted by bradders
up the preload then
job for Tuesday
Just like people did when they had bikes with twin rear shocks and wanted to carry a passenger, they just wound the stepped preload collar round a notch or two to stop the backend bottoming over the bumps
Old 04-May-2009, 01:09   #23
anyone know the std rate? just found the calculator on racetech and it says I should have 1.067kg springs, but only lists 1.0kg as max, so want to know the difference between that and standard as it says standard is 0.960 anyway!!
Old 04-May-2009, 01:42   #24
Only got info on the Ohlins FG5110 forks as fitted to the 1098S
1.0kg/mm springs, Fork Stroke/Travel 120mm
Old 04-May-2009, 01:43   #25
found a load of info here
http://old.racetech.com/evalving/Spr...pringType=Fork
http://www.ducati.ms/forums/showthread.php?t=55525
the 848 has a slightly ligher sping at .95
Old 04-May-2009, 02:30   #26
Yep thats the one where I got the PDFs from when looking into the Setup on Dallas's 1098 following his get off at Silverstone,
Opinion is that they are sprung for riders weighing 72kg rider.
so if assuming a 50/50 Front/rear bias then 36kg on the front, roughly a 90kg rider would put another 9kg on the front and if the bike weighs 180kg wet it puts 90kg on the front so spring rates would need to be about 4% higher
and so on
Rider Spring
kg kg/mm
54 0.96
72 1.00
90 1.04
108 1.08
126 1.12
Old 04-May-2009, 16:59   #27
Its about 10 pies i think.......
Old 04-May-2009, 22:52   #28
Monty's Avatar
I was going to tactfully suggest that since Paul is a 'big' lad he may need a stiffer spring-but I think you have already done that-just without the tact.....................
John
Growing old-disgracefully!
Old 04-May-2009, 22:56   #29
but looking at whats available, seems 1.0kg is all there is, and its not that much more than std so why spend the money?!
Old 04-May-2009, 23:14   #30
Yet they do up to 1.2kg/mm for the 996
http://www.motonekoparts.com/Race-Te...1-p-17992.html
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:00.
