Old 13-Aug-2011, 20:26   #21
Otei Otei is offline
Otei's Avatar
Originally Posted by chris.p
Or Crhis' come to thnik of it
Please say you realised that was purposefull irony?
Old 13-Aug-2011, 21:06   #22
Originally Posted by Jolley
Mine isn't an SS one. It is an 888 one, which shares a very similar frame to the monster. Did it myself (plus father). My monster tank was only 7.1kg anyway (including cap/hoses/filter), so I doubt you would be saving much with the SS tank, and just creating a headache for yourself.
cool, coz my question was about the 888 tank which is the same as the one in the link? May be worth a punt then at the right price. So no extra outside fuel pump then? Just swap fittings from your monster tank?
if I changed to the Ss it would only be for ergonomics; I wonder if I could use my kness more with a tank that has proper sides rather than the monster ones. I reckon the tanks are pretty much same weight
Old 13-Aug-2011, 23:19   #23
IS IT ?????
as the one in the auction link says 888/851/900SS etc
well that would be two different style frames and I can't see it fitting both
Then again it could be for the Spondon Alloy beam Frame that they built that you could fit a Ducati engine in be it a 888, 851 or a 900SS engine
Might have to dig out some old mags as I can't recall if they also did a tubed trellis frame for the Ducati engines
Either way its still a nice tank for the right money
Old 13-Aug-2011, 23:33   #24
ar yeah good point. Looks can be deceiving....altho right colour too
pics of the bottom look like a fairly open area, what do you reckon?
Old 14-Aug-2011, 08:19   #25
Yes, I did
Old 14-Aug-2011, 09:38   #26
Jolley Jolley is offline
Bikes: 959
Jolley's Avatar
The only thing I would say is you 'might' have problems with the airbox and igniter boxes (mine was tight, and it seemed to have a bigger void under the tank - though it is hard to tell).... Although a lot of people have relocated those anyway. The front mount on this one is a little different to mine, but it looks like you might just need a little plate to bolt it to.
I still have a little external pump on mine, not the one in the tank, because the 888 (I think) was fuel injected with a much higher pressure pump.
Old 14-Aug-2011, 11:16   #27
so cant be vacuum fed then ala monster tank? May still be worth a punt for next year, especially if its a couple of kilos lighetr and goes for the right money, although how heavy is the pump? The SS tank was weighed with inside pump fitted
Old 14-Aug-2011, 12:33   #28
Bikes: 959
Jolley's Avatar
That one prob could because of where the feed is. The 888 outlet is 1/3 up the tank, so I need it to get the fuel up and out. Mine had an elec pump anyway (weighs no more than 500g), so any saving on the tank is still a saving. Even if I had gone from a steel tank without pump to the 888 tank with pump, it would still be a 2kg saving.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:05.
