Old 04-Jan-2005, 23:49   #31
DSC Member AK AK is offline
AK's Avatar
ok boys here you go - and mine is a 2 valver - M1000Sie
annual service (1st year) for 6000 miles includes:
Replace Plugs, air filter, fuel filter, oil filter & oil.
Clean fuel tank
check carbs (balance injectors), belts, cyl compression, throttle body, wheel hub bearings, play in steering head bearings, valve clearance, rear wheel cush drive, brake pads wear, tyre wear & pressure.
Remember, if you do not keep to the correct servicing intervals, Ducati will not honour any problems that arise from this.
Belts are changes & shims checked & adjusted if required at 12,000 miles/2 years - more expensive service.
Am being charged £250 (this does not include oil & filter as done during warranty work last month, not does it include spark plugs, as AK is supplying them)
I thought this was a lot, compared to the first annual on the M750 - but having called 3 dealers & 2 independants its about right. It is about £100 - £150 less than is charged by a southern Ducati store tho.
your faired bikes will cost more as fairings need to come off - this is what takes the time!
Am sure nelly will be along to talk more.
C
[Edited on 4-1-2005 by CK and AK]
Old 04-Jan-2005, 23:52   #32
dave w dave w is offline
dave w's Avatar
Mood: My K5 Rocks !!!!
Carbs...... what are they !
Old 04-Jan-2005, 23:54   #33
madmav madmav is offline
Bikes: 1098
madmav's Avatar
Mood: Chilled
potato
pasta
bread
Old 04-Jan-2005, 23:54   #34
Mark Mark is offline
Mark's Avatar
Those fitted to you're honda........... CHAV!
Old 04-Jan-2005, 23:55   #35
AK's Avatar
meant injectors!:P
Old 04-Jan-2005, 23:56   #36
Bikes: 1098
madmav's Avatar
Mood: Chilled
Originally posted by CK and AK
meant injectors!:P
Meat injectors
Old 04-Jan-2005, 23:58   #37
dave w's Avatar
Mav go have a fag mate..... you know that foods no good for you :P
Old 05-Jan-2005, 00:00   #38
Bikes: 1098
madmav's Avatar
Mood: Chilled
WET WET WET !
or is it gimmie gimmie Temptation:P
Old 05-Jan-2005, 00:02   #39
dave w's Avatar
Those fitted to you're Hon..hon..hon..unrecognised word ........... CHAV!
which one ! :P:P:P
Old 05-Jan-2005, 00:06   #40
Mark's Avatar
the spunkyblade
not the type r granny car
[Edited on 5-1-2005 by flanker]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:30.
