Old 22-Feb-2005, 09:38   #31
jobr jobr is offline
Originally posted by Dseered
Originally posted by V2 PETE
my details are
registered march 2004
binned feb 2005
frame no ends in 002616
interesing to see tf's conclusion on the matter...!!!
Was yours a front brake problem, if so really scared now as yours is only 8 frames away from mine !
DCR
Get it booked in to your dealer pronto, they are just too close for comfort.
[Edited on 22-2-2005 by jobr]
Old 22-Feb-2005, 11:46   #32
weeian weeian is offline
Mood: 2 for 1 mmm :)
i have sticky brakes, were locked on when i tried to move it 1 night.
749s
reg'd may 2003
frame = 000228
Old 22-Feb-2005, 12:54   #33
Twinfan Twinfan is offline
Twinfan's Avatar
Cheers folks - keep them coming!
I should get my repair estimate around 4pm today.
Old 22-Feb-2005, 13:32   #34
monstermob 998's Avatar
As posted by neil748r
Secondly, I know someone that this front brake locking has happened to. Unfortunately he wasn't so lucky, happened on track, front locked solid and spat him off at 80 + mph! The cause was something to do with a tiny little grub screw on the lever. It had either come out or worked loose and backed out/in, whatever, the result was as above. I think you have to remove the lever to find it.
As posted by jools
I've never owned anything later than a 2001 ST, but on the these bikes the brake and clutch lever have a large grub screw near the pivot. It looks for all the world as if you can use this to adjust the lever span but this is a mistake, because if you adjust it too far the master cylinder piston doesn't return far enough to let brake fluid return and the brakes effectively 'pump up' until they lock.
Since, somebody mentioned 'grub screw' earlier on in this thread could it be a similar problem?
i recently fitted a pair of adjustable levers to my 600SS just a simple job i thought until i had brake binding puzzled by this i saw grub screw and wound it out this relieved the problem of brake binding then i noticed the original ones have same grub screw but are araldited in place to stop tampering and vibration so i loctited the new ones in place --dont know wether this has any relevance to your brake problems saw the threads about the grub screw and thought id add my 2p's worth
Old 22-Feb-2005, 13:41   #35
Twinfan's Avatar
Cheers mate. Could well be related. Fault at the factory, or should it have been done/checked at PDI?????
[Edited on 22-2-2005 by Twinfan]
Old 22-Feb-2005, 13:48   #36
twin fan --just read me mr haynes it states thats they are araldited at the factory!!!! i know the SS and 74*are a world apart but may help?
Old 22-Feb-2005, 14:03   #37
Twinfan's Avatar
Cheers - that's worth knowing. Thanks again!
Maybe Luigi was too busy having a fag one afternoon....
Old 22-Feb-2005, 14:59   #38
guest1 guest1 is offline
At the risk of sounding sexist (would I ever?!?), the visitors to the factory said that a lot of the assembly is done by wimmin.
So perhaps Luigi was too busy to keep his eye on Mrs Luigi's work.
INCOMING...!!!!!!!
Old 22-Feb-2005, 15:20   #39
Twinfan's Avatar
The ladies built the insides of the motors, but the blokes put the bits on and in frames. I think Mr Luigi himself is to blame...
Old 22-Feb-2005, 15:42   #40
pedro pedro is offline
pedro's Avatar
Mood: r
think i let tim & jon out on mine first
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:11.
