Old 06-Mar-2005, 11:09   #31
not got a 36 or 37t one have yer??
Old 06-Mar-2005, 11:16   #32
Felix Felix is offline
Another way to make sure you got the eccentric in the right area is to see which way you have to turn the adjustment spanner to tighten the chain. Quite simply, if you have to pull up on the spanner to tighten the chain, the eccentric is in the right area, i.e. below the hub.
Old 06-Mar-2005, 19:55   #33
Jasper Jasper is offline
Jasper's Avatar
This is where it should be.
Old 06-Mar-2005, 20:07   #34
greta pic - so should it be at 5 oc as andy says or 9 as the pic shows?
Old 06-Mar-2005, 20:11   #35
It should be in the 4 to 5 area in the pic, probably why that section is shaded.
[Edited on 6-3-2005 by skidlids]
Old 06-Mar-2005, 20:14   #36
Or as Geoff Baines said to me when I first got my 916 " make sure it is between 6 O'clock and 9 O'clock when viewed from the wheel side.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:07.
