Old 06-Jul-2005, 15:24   #1
guest1 guest1 is offline
fans blowing hot air into air intakes
Old 06-Jul-2005, 15:30   #2
Mark Mark is offline
Mark's Avatar
Fans were fitted the wrong way round, or spinning the wrong way round?
[Edited on 6-7-2005 by Flanks]
Old 06-Jul-2005, 15:31   #3
Fans blowing so hard they were causing a vaccuum around the airbox and actually sucking air out of the engine.
Old 06-Jul-2005, 15:34   #4
Mr_S Mr_S is offline
fan blades broken, not shifting enough air, and binding causing a massive current drain resulting in the electrical system being overworked blah blah blah...
Old 06-Jul-2005, 15:35   #5
Fans were yellow and therefore too slow?
[Edited on 6-7-2005 by TP]
Old 06-Jul-2005, 15:36   #6
Mark's Avatar
trouble maker!
Old 06-Jul-2005, 15:51   #7
Twinfan Twinfan is offline
Twinfan's Avatar
Have the fans cut through a wire of some sort?????
Old 06-Jul-2005, 15:52   #8
Mark's Avatar
Something to do with the temp sensor? Coming loose or something?
Old 06-Jul-2005, 15:54   #9
Henners Henners is offline
Flanks and Twinfan ...
... get together you're alost there
Old 06-Jul-2005, 15:56   #10
Mark's Avatar
Air temp sensor came loose, and was reading the engine as cooler, so the fan was not working or fan was blowing cold air onto sensor?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:27.
