Old 24-Jul-2005, 12:31   #31
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
Henners I don't think the R has Ti conrods? In fact I'm almost positive it does'nt
Old 24-Jul-2005, 12:38   #32
I'll just go and check............................................. .................................................. .................................................. .................................................. .............................nah - it doesn't
Old 24-Jul-2005, 15:29   #33
Henners Henners is offline
I could be wrong but ...
From Ducati Technical cafe
996R 2001: Technical Specifications
ENGINE
Max Power: 136 Hp @ 10200 rpm
Max Torque: 101 Nm @ 8000 rpm
Bore and Stroke: 100 x 63.5 mm
Displacement: 998 cc
Compression Ratio: 11.4: 1
Timing System: DOCH, Desmodromic 4 valves per cylinder
Inlet Valves: 40 mm
Exhaust Valves: 33 mm
Special Pankl con-rods Weber-Marelli electronic injection, single "shower" injector per cylinder, 54mm throttle body. New ECU M5.9
12V - 350W electrical equipment with 12 Volt 16 Ah battery
Wet sump forced lubrication, 4 liters oil
Dry, multiplates, hydraulic actuated clutch
6-speed gearbox
Pretty sure those Pankl con-rods are Ti
Old 24-Jul-2005, 15:40   #34
Only 136hp........you wanna get a powerful Ducati......
Old 24-Jul-2005, 15:43   #35
BDG BDG is offline
BDG's Avatar
I must have one of the cheapo versions as all of my literature states mine is 135bhp.
So theres my excuse for being slow
Old 24-Jul-2005, 15:46   #36
136 is the std performance figure for the 996r and 998s........the r did have ti rods, the 998 has steel. Both had the sand cast deep sump.
But this is all so yesterday........................:P
Old 24-Jul-2005, 15:48   #37
Wouldn't want one of those cheaper 999Rs -
Old 24-Jul-2005, 17:45   #38
Depends Tim .... how cheap?
Old 24-Jul-2005, 19:18   #39
it depends how long it takes to bring out the next 999 !!!!
Old 24-Jul-2005, 19:50   #40
Lily Lily is offline
Mood: stiff and tired
so, from reading this my bike is just as good as 996r...
ducking for cover....
only joking btw...
[Edited on 24-7-2005 by Lily]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:21.
