Old 27-Oct-2005, 00:19   #31
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
Just to avoid any doubt, Rushjob, look it up.
I did..... that's what got me thinking when you compare it to the two other values used in similar applications.
On the 996 the rear axle threads are M33 and M38 which only rate 137 and 157Nm respectively!
I know that Ducati have amended some torque values but on what and which way they went I couldn't say.
[Edited on 26-10-2005 by Rushjob]
Old 27-Oct-2005, 00:20   #32
ace ace is offline
ere your not my old english teacher are you ? ( did i spell it right sir )
Old 27-Oct-2005, 06:38   #33
Originally posted by HW
Don't mean to throw a socket (erm, spanner) in the works, but doesn't it depend on waht tpe of swing arm you have? Or are the later models the same nut size?
Nope,all 999/749 rear wheel nuts are the same,....36mm.
Old 27-Oct-2005, 11:43   #34
swannymere's Avatar
Mood: High as a kite!
[i]
Just a thought before a foot in mouth email gets sent out..........
Thanks,still think it's a **** take,not showing the correct socket size.:P
Old 27-Oct-2005, 12:28   #35
logyk logyk is offline
logyk's Avatar
Mood: Relaxed - don't worry about things you can't change
I am still confused as to whether there is any sort of agreement here on the torque setting to be used with a 36mm nut
Old 27-Oct-2005, 12:41   #36
Rushjob's Avatar
Mood: :-)
Wait till tomorrow Phil & ask one of the Tech guys on the Ducati stand!
Old 27-Oct-2005, 13:11   #37
logyk's Avatar
Maybe I will have to....but I was planning on removing the wheel tonight !
Old 27-Oct-2005, 14:18   #38
Rally Rally is offline
Rally's Avatar
Like I said, if you're in doubt then look it up.
(clue: click on the link)
Old 27-Oct-2005, 14:40   #39
guest1 guest1 is offline
The rear wheel nut on mine is 36mm socket size.(clue: look on your bike)
180Nm means I'm lifting the bike off it's side stand on the upswing
(999s '06)
Old 27-Oct-2005, 15:45   #40
Rally's Avatar
Hey, I'm just trying to help out here!
Yes, the rear nut requires a 36mm socket. I think we've established that.
But there seems to be some doubt over the torque setting so I put up the pdf so people can look it up for themselves. It says 180 Nm (+-10%) (or 132 lbft if you're Rockhopper )
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:34.
