Old 13-Feb-2006, 23:09   #31
Tonio600 Tonio600 is offline
Tonio600's Avatar
Mood: What a wonderful world.
Message original : mjbayley
He's another guess.
Does the engine 'spin' over with the sparkplugs removed?
Not at all...
Update: Even with the car battery the bike won't start
It seems something is telling to the starter engine to stop starting the bike after a very short time. Does it ring a bell?
Old 13-Feb-2006, 23:11   #32
Tonio600's Avatar
Message original : skidlids
Check the connections on the start solinoid aren't touching against the cylinder head.
If all OK there get a set of jump leads run one from the -Ve of the battery to s good engine earth, I find exhaust studs work well.
Then with the other jump lead connected to the battery +Ve prod the other end on to the starter motor connection, if you still only get half a turn I would suspect the starter motor but could also be a problem with the engine
Where is the starter motor connection?
Old 13-Feb-2006, 23:13   #33
Scooter916's Avatar
Mood: Hmmm Conference season
HMM, I would still swap the relays over, As you said about yours clicking, mine were too, but that may not mean that it is switching the main properly.
Just a thought tho, Stick it in gear and see if it turns over??
Glyn
Old 13-Feb-2006, 23:15   #34
Scooter916's Avatar
Tonio its under the starter motor, A rubber boot usually full of rust, you cant miss it.
Glyn
Old 13-Feb-2006, 23:18   #35
Tonio600's Avatar
ok, I'm off to the garage again...
Old 13-Feb-2006, 23:22   #36
Scooter916's Avatar
your webcam link doesnt work i was going to watch you **** about LOL
Old 13-Feb-2006, 23:39   #37
Tonio600's Avatar
Message original : Scooter916
I turned it off when I started feeling ridiculous
I've done what Skid suggested, the problem doesn't come from the starter motor, it works fine when directly connected to the battery.
I've done what you suggested, it doesn't come from the relay, I tested it on my road bike and it works fine (I mean the yellow one which is underneath the seat. btw is there another relay I could check?)
Any idea?
Old 13-Feb-2006, 23:48   #38
Scooter916's Avatar
Starter solenoid ???
next place to start.
Old 13-Feb-2006, 23:53   #39
Tonio600's Avatar
what's that?
Old 13-Feb-2006, 23:58   #40
Tonio600's Avatar
let's see if I can find it...
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:03.
