Old 16-May-2015, 21:21   #31
Originally Posted by Lee M
Hi Kev, I am unsure. I have looked at the embossed date stamp which looks like 93, the cylinder head has 8S, the belt adjusters are on the barrels and it has the rounded belt teeth.
perhaps I should try a 44 rear sprocket?
8S Heads makes it the 1999 to 2001 model, so standard gearing on the road would have been 15/46 on the Monster, they didn't do a faired SS version with that engine but if they had the gearing would have been 15/44 as standard
Old 16-May-2015, 23:03   #32
Lee M Lee M is offline
Bikes: Fire-blade, Monster 600
Lee M's Avatar
Mood: Living the dream!!!
Thats interesting as I am running a 15 front 48 rear set and its still slow. Just have to accept that "not being shy at a buffet" has finally caught up with me. This is where I need to say "its not all about the winning; but the taking part that counts". It won't stop me from enjoying myself and gives me a plausible excuse when I lose to Stafford. Thanks for everones help, see you at Snetterton.
Old 16-May-2015, 23:10   #33
48T rear is going to be way to big for Snetterton
Go for a smaller rear and get more out of each gear
Old 16-May-2015, 23:33   #34
Lee M's Avatar
I am not racing at Snetterton due to my family holiday a week later. But from the track day I day there about 2 weeks ago I didn't manage to grab 5th gear on the straights unless I short shifted and Mark No 81was making at least 30 meters on both straights on standard gearing on a 1995 600SS.
Old 17-May-2015, 23:38   #35
SeeleyG50 SeeleyG50 is offline
Bikes: 500 Pantah, TT2, 749R, 944ssie, Rickman Kwak 1170, Yam 1200 Super Ten
SeeleyG50's Avatar
Mood: The Older I get the Faster I Was!
Jeez Lee. Have you actually got around to setting up/dyno-ing the engine yet? A simple dyno run would/will reveal if all is well. Count the teeth on the primary gears to check what ratio you have. You can't re-bore Ducatis in the conventional sense! If the original honing marks have disappeared, then the bore is probably shagged (technical term).
Old 18-May-2015, 21:25   #36
Lee M's Avatar
Hindsight is a wonderful thing. I original said to myself that I would run the bike on a dyno and that would prove if the acceleration problem was the engine or me. But the logistics of the dyno test against having a compression tester at hand in my garage didn't equal out.
I suppose this is where it all started to go wrong. Patients is a virtue and I went "bull headed" into stripping down the engine on the back of the compression test instead of running a dyno.
Lesson learnt.
Old 19-May-2015, 09:17   #37
badgerpilot's Avatar
Here's another lesson.
Don't let a mint, proven, Ghostie fettled engine slip your grasp at the end of this season!
Scott #50
Old 19-May-2015, 09:29   #38
milesaway milesaway is offline
Bikes: 900ss 600ss xr400
milesaway's Avatar
Lesson learnt.
I wouldn't beat yourself up over that- if you did the comp test right and there was nearly no compression you know what the dyno would say without having to run it!
Old 26-Jun-2015, 17:14   #39
Lee M's Avatar
So to recap I have stripped the top end, lapped in and reshimmed the valves. Checked the piston rings and bores, reassembled again carrying out a soft solder squash and setting the base gasket..... well today I took it for a dyno test, changed a faulty ignition coil which was causing a misfire
The read out was just got over 47bhp but was set to 46.7bhp to get a better torque curve.
Uhm.....what 4 bhp between friends when your a fat lad.
Mark No81 who has a standard 600 ss produced 46.8bhp.
Roll on Mallory!
Old 29-Jun-2015, 00:32   #40
What's the cam timing set to Lee
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:43.
