Old 14-Jan-2009, 19:39   #31
nogaromill998 nogaromill998 is offline
nogaromill998's Avatar
As far as I am concerned I have no truck with cheating. As far as I am aware I have neither broken nor infringed any rules, neither have I gone against the spirit of DesmoDue. To harp on about keeping costs down is just nonsensical when you permit the use of plenty of non standard parts. EVERYTHING in my engine is standard, and within factory tolerance, as it was last year and will be next year. What I have had done is good assembly practice, no more no less.
Old 14-Jan-2009, 19:39   #32
Originally Posted by AK
i am so glad we dont do this any more.
have a nice day everybody, as we do now
sorry if you think i am taking the pi55 but this is something i realy dont miss
just goes to show you have to be careful what you say as blueprinting means putting the engine together properly as not many factory engines are put together to within close tolerance.
What nogaro has done is the right thing for the engine as in putting it together properly which some people call blueprinting.
im going to butt out now as my 6pworth is just spent.
I know what you mean Alan, SoT rules were always quite easy to comply with but then again it was far more costl than DD.
What rules a series does have need to be clear, for that to happen we need to close out gray areas
As for blue printing there is the large factory way or the small team way.
Large factory, take 1000 of each component and find a pair that best meets the design spec and use them, no modification required
Small team way, take the pair of items that you have in your engine and modify one so that it matches the other.
Now if you go some where in between and start with several items and get them matched up as best as possible without modification then thats fine by DD rules but if modifications are carried out then rules are being broken.
What would be next porting/flowing heads so that both heads flow exactly the same, anybody got the factory figure for the CFM of a 620 cylinder head, I know the rules say no material can be added or removed but surely its just good practice and therefore I should be allowed to do it
Old 14-Jan-2009, 19:41   #33
a month away tim just a month
and yes, i like to delve in here on occasions not to remind me of the politics and borrocks that i dont miss any more, but to enjoy the banter with the dd people still.
after all if it wasnt for dd then we wouldnt be doing what we do now in running in a great club which has televised racing all season
A month? Is there a class for these?
Old 14-Jan-2009, 19:41   #34
vespa vespa is offline
Bikes: Super Twin 800; DD B; S2R 1000
vespa's Avatar
Mood: DD class B
Originally Posted by nogaromill998
Not at all Tim, cheating should not be allowed. My understanding of the rules is that no mods are allowed to the crank, and as far as I can see balancing a crank is merely good practice, not cheating in anyway, as I have already said, it is absolutely bog standard in everyway, with no performance enhancement inferred or gained from just putting the thing together properly. I handed them a crank, 3 sets of rods and pistons and gudgeon pins, circlips piston rings etc and told them to balance the thing.
That's what I understand. It's like putting balancing weights to the wheels then
Old 14-Jan-2009, 19:43   #35
Very good analogy Alex, you are adding material there but it gives no performance advantage, just makes the wheel run correctly.
Old 14-Jan-2009, 19:44   #36
PMSL
Old 14-Jan-2009, 19:47   #37
paynep's Avatar
Mood: Wet wet wet
the rules also state :
Wheels including diameter and rim width must remain as originally produced by Ducati since 1992 for the 600/620 bikes.
Front wheel 17” X 3.5”, Rear Wheel 17” X 4.5
but we all know 748/916 wheels are used......I think some common sense needs to prevail here.
Quite right re the last sentence
For example the same front wheel (501.2.069.1AB) is fitted to both MY03 620 and 750 Monsters.
So if I took a front wheel off a 750Monster from another year and used it, would it be illegal?
Mind you, my bike has a 900ss frame, Mhe900e forks, a 750ss rear wheel and an ST2 front wheel so I might as well be banned now and save on all the race entries...
Old 14-Jan-2009, 19:54   #38
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
Stick bit's of lead on the crank
Old 14-Jan-2009, 19:56   #39
Lily Lily is offline
Mood: stiff and tired
count me in.. i can crash them just as well as a DD bike
Old 14-Jan-2009, 19:57   #40
Bikes: 916 Strada
Chaz's Avatar
Talking
Originally Posted by ChrisBushell
Alesandro,
I have confirmed this afternoon that the pistons are available from the factory, please contact Ducati Coventry and they will sort you out.
Ultimately the rules have been the same on balancing (that it is not allowed) since the start of the series and from memory we have only had one motor blow up (Ali's fire in year 1). To a certain extent balancing, expecially on the Class B engines is not worth the expense as they do not rev that high anyway and are somewhat overengineered for 52bhp.
Say no more He that should be obayed has spoken.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:41.
