Old 02-Apr-2009, 08:45   #1
Chef Chef is offline
Bikes: 998S Chili trackbike,749R (corse kit), 748SPS
Chef's Avatar
Mood: Flange - it's a state of mind....
998S Stutter between 2.5K & 5K rpm
My 998S has developed a stutter between 2.5k & 5K rpm
Happens on open & constant throttle - okay before & after....
All electrical system short of replacing the loom has been checked - all fine
Just had a 12k service etc
Bit gutted as can't take to Park Algar now as needs to be dropped off on Sunday
Any ideas.......
Thx in advance
Old 02-Apr-2009, 09:29   #2
You know it makes sense;
Sorry mate, couldn't resist
Old 02-Apr-2009, 09:29   #3
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
Any ideas.......
Thx in advance
Sounds like fuelling to me, check Pc if you run one also injectors & TPS.
Old 02-Apr-2009, 10:24   #4
Chef's Avatar
Tim - check your mobile - the R6 is booked!!!! as are the pirelli diablo supercorsas, paddock stands etc etc
Bring it on
Chaz - PC has been checked & disconnected
What is TPS...
Thx
Old 02-Apr-2009, 10:37   #5
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
Throttle position sensor.
Old 02-Apr-2009, 10:47   #6
Lily Lily is offline
Mood: stiff and tired
Nice one mister, you can play with us other traitors on non Ducatis
hope you get it sorted soon though!!
Old 02-Apr-2009, 11:04   #7
Chef's Avatar
TPS (now I know what it is!!) has been checked too....:-)
Not sure injectors have - is that part of a 12k service....
Lily - I know!! - what are you on.......
Was think of getting an ex BSS R6 late last year.....then the credit crunch hit.............mmmmmmmmm.........be a good chance to try one out
Ta everyone
Oi - Tim - do you like my new avatar...........:-D
Old 03-Apr-2009, 19:16   #8
Mojo Mojo is offline
Stutter
Had a similar problem on 996 last year and finally tracked it down to a split in the rubber fuel line directly after the pump. This means going into the tank but you can combine it with a fuel filter change which is how I found the problem.
Hope this helps.
Old 03-Apr-2009, 20:43   #9
wouldnt fuel filter chnage be part of a 12k service? in which case maybe moving things made it worse
Old 03-Apr-2009, 21:27   #10
Hope this helps.
Good suggestion! This reminds me of a chat I had with Ducati John the other week as he was sorting a 996 or similar with just that problem at the time. Apparently it is quite common and is only a 20 minute job to fix.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:40.
