Old 13-May-2009, 18:59   #31
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
Originally Posted by Rattler
Hmmm, there aren't too many who have switched from 583 to 620 and matched their previous results though. It deffo took Andy S a while to adapt, Chris W, Phil H didn't match their results initially, obviously the exam paper is somewhat harder (in terms of competition), but not sure about how much better their lap times were either?
I've not ridden a 583 at all, so no expert here, but as a discussion point, does the fact that the throttle on a 583 can be wound fully on before a 620 one could (by normal riders like us) give riders more confidence to go faster? As its one less thing to worry about? Maybe it just tales time?
I remember a test day at Snett, when I was matching / catching a quickish GSX600 rider (racer) on corner speed around bombhole-corum on my ol' 620 and whilst it wasn't all full-throttle for me, it was nowhere near for him, he had decision to make on throttle opening and I didn't really, and I closed on him.
Gawd nose!!! - but Jimbers seems to have found his DD mojo since mounting a 583, I reckon he would go faster on a 583 than a 620????
When Lily's not crashing , she says her laptimes on a DD bike compare closely to those on her 998. Familiarity, or fear of the unknown? :dunno:
So is it fear of the awesome power, torque and drive of a 620 over a 583?
Or is it that that they weigh a ton? Or is it just to have a little bit more power means you have to be a little bit more cautious?
Or perhaps there's less to fug about with on a 583 and hence the tinkerers like you and Payne can really mess up a 620 !!!! and slow it down.
The answer? Only go near it to ride it..........and if it aint broke.......!!!
Fwiw. I think one of the biggest things that you have to adapt to is the speed difference between the two aproaching a corner. You are always more likely to roll off too early after stepping from a 583 to a 620. There isn't a fantastic amount of difference in the top speed, but even that extra 5-10 mph will have you braking a long time before you did on a 583.
Old 13-May-2009, 20:20   #32
tomtom tomtom is offline
tomtom's Avatar
My 620 was too much of a dog to just get on and ride it at first. In hindsight i wish i'd never touched it; the exhaust bellowing smoke, the wooden seat. It would have all been better than the embarressing few horses towing it along now. I think i'll trade it in for three beans
Old 13-May-2009, 20:24   #33
Matt-T28 Matt-T28 is offline
Matt-T28's Avatar
Mood: 2008 Desmodue Class B champion
Just my two peneth,
I had a ride on a 620 that whilst was very well put together, was not super trick at the end of oct last year at mallory in the cold and got down into the 1:01's in three sessions, i'd done 1:02.97 on my 583 when we raced there at the first round. Really didn't feel any different in the places you could open the throttle on it, and it turned and stopped far better than my 583 did.
I do think that its in the mind as the difference in power is pretty much negligable, its not like the difference between a 600 and a 1000 jap four.
Jimbers really has got on well with the 583 though so far, couldn't believe it was the same person after watching him at anglesey!
Old 13-May-2009, 21:55   #34
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
Originally Posted by Matt-T28
Just my two peneth,
In fairness your 583 was fresh at the start of the season & the 620 was tired with 4 or 5 bhp down after a hard season & in need of a refresh.
Old 13-May-2009, 22:19   #35
MLC Racing MLC Racing is offline
MLC Racing's Avatar
Mood: Moto Guzzi are the new Ducati??
Mmmm
How would removing FIM's and Power Commanders affect the 620's and could the weight difference be made greater to find some of the difference?
Old 13-May-2009, 23:01   #36
The trouble is the one I bought was broke and did not run any improvement on that isn’t really messing it up.
Going with the 750Ssie ECU has its problems, the rev limiter kicks in at 9200rpm meaning you have no over rev, also it is normally connected to injectors that are designed to flow 22% less fuel than those of a 620. Then there are the slotted/adjustable cam sprockets which means the cam timing can be all over the place. On one of my cylinders the inlet was opening at 4 degrees AFTER TDC when measured at 1mm of lift, the Standard Factory figure is 12 degrees BEFORE TDC, so having cams retarded by different amounts and by up to 16 degrees doesn’t help.
With Only 55bhp on tap compared to my 583s 51.5bhp I doubt if its anything to do with the throttle opening after all it’s a pussycat compared to the TL1000S and 916 I raced in SoT and the Blades I ran in the Open and Powerbike. Paul P probably thinks the same of his 620 when compared to the 888 based bike he use to race in SoT
The Frustrating thing is I bought a crashed but complete M620Sie to turn into a race bike, it came complete with two black keys, the red master key and the code card yet did not want to run. I spent hours and hours going over everything to try and get it sorted, but there was nothing I could do with the standard parts, either the clocks or the ECU were prohibiting me from getting it to run. I tried the breakers for second-hand set-ups but there were none available, a FIM was outside the budget so I opted for the 750Ssie ECU route
My advice to others is to start with a running 620 that is either using a standard ECU or something like the FIM unit on Trouty’s bike or a bike with a proven record
Old 13-May-2009, 23:11   #37
Tonio600 Tonio600 is offline
Tonio600's Avatar
Mood: What a wonderful world.
I have improved on the 55bhp I had at Donington.
Which is still a lot better than most 583s...
Old 14-May-2009, 00:35   #38
andys 900ss's Avatar
Eh?? You've lost me there Kev after the word problems...
For what its worth I've done reasonably well in both classes. I found, as did many others, (Fil, Chris Wood, etc) the bikes to behave totally differently. Cobby has also rode both bikes and enjoyed the handling of the 583. The 583 engine has different weight and turning characteristics to the 620 so we found the bikes needed to be ridden differently. I've had to learn alot of racecraft with the 620 as it takes more care to ride faster than the 583 but once mastered you can cane it just as much as the 583 and pull 3-4 secs a lap (on average over the tracks) faster, but the 620 will bite back! As its going faster than the 583, its also more on the limit of the tyres.
Dont forget I have a very capable 620 for sale if someone fancies the transition.
This is just my opinion.
Andy
Old 14-May-2009, 03:07   #39
Chris Wood's Avatar
I have to agree with Jon, Andy and Tim's views.
620s' are much quicker, in the right hands, ex racers - Geoff, Cobby, Dom, Hawk etc (look at the records)... or those who have spent a few years learning how to ride them - Rattler, Andy. Very FEW amatuer racers, have transitioned from 583 to 620 quickly and easily.
Personally on my 583 I could be very direct and (clumsy?) when riding it and hussle it about. The 620 required more finnese? as it was going much faster, as Jon said, at the critical points of braking and in sweepers ie Assen or Cadwell! 5th gear flat out up Charlies on the 583, no problem? on the 620, clench sphincter!!
620's are more on the limit of tyres I agree completely.
I have ridden a number of 583's and 620's. IMO for a newbie, the 583's are easier to ride well, by virtue of their setups. The 620's are more difficult to ride quickly as you need much more confidence and learnt ability.
For me class A is just having a rest.
Leave it well alone and go race.
You, lucky, lucky, b4rstards.
Old 14-May-2009, 11:22   #40
Lily Lily is offline
Mood: stiff and tired
haven't ridden a Class B bike so cannot comment, but I do know that the Class A bikes are not always that easy to ride. It takes some serious adaptation of riding style to get along with them as they are moderately quick but still bite back.
I am clearly having some tyre issues at the moment as I have had the back let go on me twice now on fastish corners, not something i have had previously and maybe due to me swapping to the bigger bikes with slicks in between?
Not sure what the answer is tbh, i think we need more people to try Class A and see how they enjoy it as it's hard work at times but rewarding if it goes well.
I am sure we will be back at some point, just cant say when that will be just yet!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:21.
