Old 17-Sep-2009, 17:46   #31
Originally Posted by Andy C
In the scheme of things is this such a big problem!
For me it is, I want to shop around for the best deal. I also like to fit and balance my own boots, another cost saving.
Old 17-Sep-2009, 17:55   #32
Originally Posted by andys 900ss
We found the ZR tyres took longer to warm up which is probably a benefit in DD, especially Class A as I now find the HR tyres go-off quickly on the 620's. Kyle found them pretty good too, looking at some of his old lap times. We find the HR's very good at their first meeting and not-so-good at their second meeting and I'm sure Tim will confirm this too.
As Tim has not yet posted, I can confirm with Andy that after one race let alone one full meeting the HR Diablo's on a 620 have lost there initial grip and start to slide noticably.
Apart from that they are a good reliable and consistant tyre.
Old 17-Sep-2009, 17:57   #33
Originally Posted by MLC Racing
Should we concentrate on policing adjusted pick-ups then?????!!!!!
Is adjusting the pick-ups illegal??
Whats a Pick-up????
The two flywheel pickups for the ignition triggers are on a slotted bracket. you can get about 8 degrees of advance on there.......if you wanted
In short, realistically, no you couldn't police it. You can move them 2 degrees tightening the things up.
It's a red herring that would take up valuable time/resource IMO.
Old 17-Sep-2009, 18:06   #34
ChrisBushell's Avatar
Mood: Im Going to Italy soon!
Neil,
Well put and it would require a protest and an engine strip to prove.
Old 17-Sep-2009, 18:34   #35
DSC Member AK AK is offline
AK's Avatar
Just my tuppenth worth on the CDi boxes. As i understood them they had a modded curve in but not necessarily for more power. The ultimate advance needs to be kept in check to enable them to run on any fuel and Ducati know this.
I've certainly seen no advantage of note in using them. What they did/do give was/is a monetry saving in replacing the stock boxes should they fail. The DP items are cheaper, as a pair, than buying stock parts. This has a been a reason that i know of in two cases where they have been used.
There's more adjustment to be had on the pickups and you'd never police that, so for what it's worth, i think you'll be wasting time, effort and energy trying to police the DP igniter boxes.......
i agree 100% with all above as nelly knows what he is talking about rather than some other people that frequent this forum
Old 17-Sep-2009, 18:35   #36
Originally Posted by ChrisBushell
Neil,
A strobe lamp would do.
That isn't the issue, if adjustment is there thats why its slotted but that is only for the static/idle advance the igniters provide the advance over 3k, and as Nelly says there is no advantage with them.
Run too much advance with incorrect RON fuel and it will pink like hell and get you nowhere.
Old 17-Sep-2009, 21:09   #37
MLC Racing MLC Racing is offline
MLC Racing's Avatar
Mood: Moto Guzzi are the new Ducati??
Talking Yeh but....
If we only ever spoke about what we knew about the world would be a very quiet place....
we'd never learn anything new...
or have anything to whine about....
or laugh about....
Old 17-Sep-2009, 21:15   #38
Imola Duke's Avatar
As per Skids post re pistons.
I looked into this and they were £300 for 2..
But I understand now you have to buy the cylinders ?
Mine after 2008 were well worn and scored and when measured were well
under tolerance.
JE pistons could be a option as they make 4 off to order.
and half the price
Also for next season The Scruts will be hot on shark fins and they will need
to be like the one Chaz had made up ( I got pulled up on mine at CC and bernie explained to me and showed me Chaz's template)
Thanks for my shiney new one Chaz
Old 17-Sep-2009, 21:22   #39
Yeah, but to what purpose. The facility is there, as standard, to adjust the ignition advance/retard. One DD'er could argue they had no idea.... plausible. The other could argue that having measured the TDC point the stock markings are out. Very plausible.
The pickups are the trigger for the CDi's. Move the plate 2 degress and the whole curve is moved 2 degrees. The ignitors simply carry the curve data. There's your advance.....
Why then would you go on a mass witch hunt for the either the DP ignitors or altered pick up positions?? It serves no purpose
The nett results of any tweaks to the ignition are neither here nor there.
IMO, the only mods worth any significant gain are flywheels, pistons and heads. These are easy spots and the tests are well known. Why spend 50 quid on a protest and waste the time of the officials chasing pickup positions when you'd get more advantage from a wearing a slicker helmet or tucking your elbows in a bit tighter.......
It's a waste of resource and time. The DD is supposed to be a simple series.
Old 17-Sep-2009, 22:04   #40
dunlop0_1's Avatar
Never mind all this tech talk. MORE LAPS PER RACE PLEASE. 8 seems to be over so quickly or is that just me being a slow starter. LOL
Keep it as cheap and easy as possible.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:27.
