Old 07-May-2005, 09:57   #31
Walenut Walenut is offline
Mood: Erratic
Originally posted by Mike Davis
Dickieducati, I think youve got a bit mixed up with how changing profiles affects the bike if you go from a 60 to a 65 or 70 profile tyre of the same make/type it will in actuall fact slow the turn in down, because in effect you are raising the front ride height
Why would raising the ride hight effect the turn in? That's what your doing with the rear when you go from 190/50 to a 180/55 and that speeds up the turn in?
Old 07-May-2005, 10:10   #32
Mood: Erratic
Is it because you've lengthened the wheel base very slightly and altered the rake? So in that case turn in would be quicker with a 60, but there is less tread area so when cranked over we are running right on the edge of the tyre area, but would this matter on the road, when its rare that you get a bike that far over?
Old 04-Jun-2005, 22:22   #33
bagonails bagonails is offline
I had a 748sp with pirellis as standard which were dead good. After some years of sticking with them I found they wer'nt so good. This could have been down to suspension settling down or maybe the compound getting harder over the years. Pirelli and Metzeller are the same tyre, made by the same tyre company, just with different tread designs. I did find after some lower gearing that my 748 used to wheelspin in the wet. I eventually changed to Dunlops, its a matter of choice really.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:31.
