Old 21-Mar-2005, 17:50   #41
cmoss cmoss is offline
Today made up the mounting brackets, rubber mounts under each mounting. Just needed to drill extra hole in headlight shell.
[Edited on 21-3-2005 by cmoss]
Old 21-Mar-2005, 17:51   #42
yeti yeti is offline
yeti's Avatar
Originally posted by cmoss
Was thinking the same Yeti.
[Edited on 20-3-2005 by cmoss]
Not sure what you meant with the images C, can you expalin?
Old 21-Mar-2005, 17:56   #43
Now fitted the Dash, place well back so Brembo's don't touch on full lock, also will help with the bright light.
Now just need to mount the indicator/Petrol module, I have cut it away from Speedo housing. Need to do a bit of work with this.
How can I post multiple images ?
Old 21-Mar-2005, 18:07   #44
The Indicator/petrol module will fit underneath the dash, the wiring harness is just long enough.
Old 21-Mar-2005, 19:03   #45
yeti's Avatar
C, what is the small round box with the red LED? Also have you remembered to take a pick up for the low oil pressure warning light that's normally in the tacho?
Old 21-Mar-2005, 19:12   #46
Simon Reed's Avatar
Mood: Cool as **** !
it's an led, for is meta alarm !!!!
Old 21-Mar-2005, 20:17   #47
Yes the small round plastic bit is the warning led for alarm. The Dash has a oil pressure wire which links to the oil pressure sensor from the Ducati original, so all should be taken care of.
Old 22-Mar-2005, 18:46   #48
yeti's Avatar
Yopu sorted out which wire supplies the feed to the oil pressure warning yet C?
Old 23-Mar-2005, 17:03   #49
Hi All further update, now fitted the indicator module, all ok so far now this week start to wire up the main conections then work on the speed sensor fittment.
Yeti most of the connections are straight forward and can be picked from the connections in the headlight shell with the looks of things, will double check with the old Haynes manual thou.
[Edited on 23-3-2005 by cmoss]
Old 24-Mar-2005, 15:31   #50
chris99 chris99 is offline
Mood: building the beast
Its looking nice matey. I would love one of those but it looks like it may be a bit complicated for me
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:14.
