Old 07-Apr-2005, 23:18   #41
Ducnow Ducnow is offline
Originally posted by nathanhu
duc now
arent the lock stops on the 999 cast on the lower yoke with small screws
I'll check that tomorrow.
Old 07-Apr-2005, 23:26   #42
dave w dave w is offline
dave w's Avatar
Mood: My K5 Rocks !!!!
heheh
dave hows the bike going ???
i pick mine up next week...... cant wait
Splendid at the moment.... have had some small problems but nothing to major.... taking me some time to get set up for me... Just don't need all this plug/coil/ecu long list problems people are having ! Good luck with yours mate
Old 07-Apr-2005, 23:34   #43
nathanhu nathanhu is offline
nathanhu's Avatar
Mood: head down
i had the coils changed before i pick the bike up
the new type have a tail type plug rather than the plug directly on the coil
Old 07-Apr-2005, 23:40   #44
You're getting a 999R?
Hmmmmm...... those new coils are from the 05 models?
Every models or just the R model?
btw......... wtf is a coil ?
Old 07-Apr-2005, 23:41   #45
dave w's Avatar
How does that work then.... Just had a look at mine, there made in germany... BERU
Old 07-Apr-2005, 23:50   #46
nathanhu's Avatar
Mood: head down
the 04 bike had the old coils fitted (they look like the the spark plug caps but with thinner wires) these coils had the connector plug attatched the the coil at the cylinder head.
the new 05 ish ( as some later bikes came with the new coils)
have a cable leading off from the coil about 10cm with a connecting plug on the end.
to tell the difference -
on the rear / standing cylinder the sparkplug cap/coil should just be visible from the left hand side.
if the plug attaching to this coil is stituated directly on the cylinder head this is the old type
Old 07-Apr-2005, 23:54   #47
dave w's Avatar
Old type on mine then Only a matter of time then !!
Old 07-Apr-2005, 23:57   #48
nathanhu's Avatar
Mood: head down
the problem is with these old coils and plug arrangement is that the contacts in the wiring plug (AMP type) start to corrode and build up a layer of oxydisation on the mating faces thus causing an earth fault to the front (mostly) cylinder.
the short term rectification is to disconect the coil and remove it .
inspect the inner contacts of the LT wiring plug looking for green tinge the the contact faces
do the same to the coil
spray a little WD40 into/onto the coil Lt plug
iff it happens all the time then twist the metal prongs inside the coil 1-2 deg to help induce a better / tighter fit to the LT plug
Old 08-Apr-2005, 00:01   #49
nathanhu's Avatar
Mood: head down
any "good " dealer should do this under warranty as they all know about this problem
Old 08-Apr-2005, 00:08   #50
Wow, priceless info there nathanhu, thanks
I guess i have to call my dealer.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:39.
