Old 06-Jul-2005, 16:05   #1
JR JR is offline
Mood: 748s and me, Raring to go!!!
Some cotton thread wrapped around your Fanny Bits?? causing your baby to get all hot and sweaty??
What was the question again??
Ps you need to ride in the rain more often.
Please put us out of our misery!!!
Old 06-Jul-2005, 16:20   #2
Twinfan Twinfan is offline
Twinfan's Avatar
Fans going overboard made the air temp sensor think it was cooler than it really was. ECU didn't compensate for the heat, so it was running rich at high revs therefore losing power???
Old 06-Jul-2005, 16:46   #3
ziggi ziggi is offline
ziggi's Avatar
the twist grip got too hot and un-glued from the handle bar and when you twisted it only twisted the grip and not the throttle slide
The engine was directly powering the fans and not the rear wheel
Are these latteral enough?
Old 06-Jul-2005, 16:47   #4
ali ali is offline
ali's Avatar
Mood: Damp
Several fans were arrested during a heated exchange???
Old 06-Jul-2005, 16:49   #5
Oooh Henners you are a tease !!!
I'd have a guess, but I can't be ars...
Old 06-Jul-2005, 17:00   #6
Fans have cut a wire to temp sensor? or fans vibrate a connection loose?
Old 06-Jul-2005, 17:10   #7
Henners Henners is offline
JPM is the winner
Somehow the air temperature sensor feed wire managed to get dislodged and came into contact with the edge of the blades on the second radiator fan. When the engine got really hot the fan fired up and the blades started to chaffe through the senor feed wire disrupting the signal and confusing the CPU - which affected the fueling. Once the temperature dropped the fan switched off and the exposed wire intermittently got blown/knocked against the fan housing causing ongoing false readings and bad running.
Carl at Snells figured it all out and showed me how it happened - thanks for joining in folks and 1st place to Freak who got it spot on - except Jools of course who couldn't be ar$ed
Old 06-Jul-2005, 17:20   #8
Ooooh
A prize coming my way? A virtual beer?
Old 06-Jul-2005, 17:21   #9
Mark Mark is offline
Mark's Avatar
smack in the gob
Old 06-Jul-2005, 17:23   #10
It'll be a broked/chaffed wire which has since been replaced
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:36.
