General Motorcycles only
Old 09-Jan-2006, 19:46   #41
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
Originally posted by butch890
had a long chat with magnetti merrelli about this today,if your bike has never been run with the red key your clocks are uncoded ,if it has you will need a blank set of clocks to run it.
As long as you dont use the red key the replacement clocks will remain uncoded,therefore my earlier suggestion satnds.
Butch
And normal procedure is to code them at PDI as I'm led to believe.
Old 09-Jan-2006, 20:33   #42
butch890 butch890 is offline
Mood: Enjoying Togdom !
Originally posted by NBs996
I'm getting too confused! Think I'll just plug in the laptop and hit the override button!!
So butch, are you saying that the system will demobilise without getting a signal from the clocks?
twpd - sadly, my budget is saying no to a FIM ecu
My information is yes.
Dave reillys bike was started when new with the red key,after his off at snetterton a secondhand (delivery mileage) uncoded set of clocks were fitted and hey presto it ran fine!
Butch
Old 10-Jan-2006, 20:07   #43
phil_h phil_h is offline
phil_h's Avatar
But has anybody tried disabling the immobiliser - which could simply 'uncode' the clocks - and then tried using them on another bike ?
I think I'm going to have to try this out with the race bike's clocks, and then fit them on the road bike to see what happens.
I would really like a get-out-of-jail routine in case it mucks up one of them !
I hate working without a specification
Old 10-Jan-2006, 20:15   #44
There's still the problem of being able to run without the clocks. Who wants to use std clocks when just a tacho is needed? Is there a way of disabling the immobiliser? Steve at Italia in Lincoln wasn't aware of one.
Old 10-Jan-2006, 23:20   #45
phil_h's Avatar
Owner's Manual page 16 is titled
'Procedure to disable immobilizer engine block through throttle twistgrip'
Old 10-Jan-2006, 23:25   #46
I've seen that but that doesn't permanently disable it, does it? Nor does it get around not being able to run without the clocks which, is what I need to do.
This is a total nightmare, isn't it?
Old 16-Jan-2006, 23:21   #47
phil_h's Avatar
Got a copy of the updated haynes manual today - it has a much longer write-up than the owners manual :P
- the manual disable is temporary.
- it doesnt mention the clocks at all - mostly just the ecu, with a brief note (chapter 4 section 7 paragraph 7) '... to allow information transfer between the decoder and the ecu ...' so i would guess the clocks have a 'secret' decoder function which stores all the key transponder ids.
Old 16-Jan-2006, 23:29   #48
phil_h's Avatar
I've just looked up the fim u59 price - £450 from sigma !!!!
That sounds like a spare set of clocks, ecu and power commander to me
Old 16-Jan-2006, 23:41   #49
ericthered40's Avatar
Mood: renegade sexy racer
Power commander £195
New clocks £365
ECU ?
Old 17-Jan-2006, 11:43   #50
phil_h's Avatar
So lets add it all up properly then ...
(all contributions gratefully received)
fim u59 = £450 from sigma
race tacho = £200 +
total about £650
clocks = £365 (list ?)
ecu = £100 second-hand ?
pc3 = £200
total about £665
(then add setup costs to either route)
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:03.
