Old 09-May-2006, 08:20   #41
jgriff jgriff is offline
jgriff's Avatar
Seems to be coming along fine. No rush on the pics. Thanks for the thought.
Old 09-May-2006, 18:11   #42
phil911 phil911 is offline
phil911's Avatar
Mood: Privileged ...
IMHO, you made a mistake regarding the rectifier location.
Shorter are the alternator wires, longer is its life.
Thus, you avoid burning connectors (even with the small Racing mod. 180 W ...) and all the electric risks supposed to start and create troubles from the rectifier.
Reason why the best location is beneath the carbon battery holder, just in front the the inferior fairing hole, like Racing bikes.
Moreover, don't hesitate to add a braid cable between the rectifier body and the frame or engine, according to its location, in order to enhance its own reliability ...
Old 09-May-2006, 18:15   #43
phil911's Avatar
On Racing bike, here's the original rectifier location ...
Phil911
Old 09-May-2006, 19:34   #44
Mr. R Mr. R is offline
Phill was your racing bike fitted with a starter motor as standard ?
Steve
Old 09-May-2006, 21:24   #45
phil911's Avatar
Steve,
Starter motor not as standard.
I managed by myself in order to be independant in case of track experiences ...
Some 94 have been fitted, if requested !!!
Phil911
Old 10-May-2006, 08:08   #46
851neil 851neil is offline
Mood: need a bike...
Phil, I've fitted a reg/rect that can cope with all of the rigours of full loading from lights, battery charging etc etc...so for the application this is overkill !!
As you know the circuit prepared will have starting and battery charging to cope with.
The problem I have is the size of my reg/rect - it's too wide and overhangs the battery mount case substantially.
So it's not like yours, where it fits snugly within the width of the battery mount case, so I opted for the current position.
The joys of project building eh ! changes to the original arrangement are at times a necessity - even if not preferred !
Old 10-May-2006, 08:23   #47
phil911's Avatar
I understand, Neil ...
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:50.
